TRAXXAS技术视频第一期 如何粘轮毂和胎皮
17-4-11 15:19| 发布者: rcfans| 查看: 9327| 评论: 4|原作者: Traxxas
视频原创发布者BY TRAXXAS,翻译者BY TRAXXAS中国总代理电波模型。作为一名新手,您是不是在为粘不好轮胎而苦恼呢?希望看到这个视频能帮到您!以下是中国TRAXXAS总代理电波模型帮做出的翻译视频,因模型涉及到专业英语,如若翻译有误,欢迎指正!
以英文原档为准,请参考:
TRAXXAS How To Glue Wheels And Tires
Traxxas wheels and tires give you endless options for customizing your model with many finishes and tread patterns to suit your environment and driving style.Traxxas offers a full line of wheels and tires and preglued sets. However you may want to customize your model  by gluing your own tires and wheels with the many combinations available. It is important to see and glue the tires properly to ensure that the tires stay sealed and balanced.
If you ever find that your tire has separated from the wheel use these techniques to reseal it. Along with your new wheels and tire you will just need a bottle Traxxxas ultra premium tire glue, a pair of safety glasses for eye protection and a mild dish washing detergent or glass cleaner.
The glue bonds quickly so consider the appropriate clothing and workspace when performing the assembly. Some tires are directional so make note of the direction of rotation and ensure the rim faces the outside of the tire. Some wheels are specified for the fry or back so make note of any indications on the wheels.
Apply the cleaner to the wheels and tires giving particular attention to the tire bead to remove any chemicals or oils that can keep the glue from bonding.
Allow the wheels and tires to fully dry gradually work the wheels into the tires. This process can take some times but be patient and allow the foam and rubber to conform to the rim go around the wheel and seat the bead of the tire into the rim on both sides.
Pull back on the tire and apply the glue as you work the way around the wheel.
Apply the glue at several points around the tire until it is secured to the wheel.
Allow the first side to dry for a few minutes prior to applying glue to the other side.
Allow the glue to dry overnight before running the vehicle. If one of your original wheels is showing signs of separation use the same technique to reglue the tire. Clean any dirt or debris from the separated area and reglue.
http://rcmart.taobao.com/
    引用 自由大帝 17-4-11 18:05
    还以为有icon图~~~
    进来就是纯粘胎好桑森~~~
    引用 黑色飘移 17-4-11 18:43
    老拿妹子作标图,进来什么都没看到
    引用 要happy 17-4-12 09:50
    沾胎还好,想知道换胎怎么搞,难道没人留轮毂换太皮
    引用 lcr1208 17-4-12 10:47
    咋没有妹子?差评
