Serpent Viper Flow 前保险杠
17-7-7 16:19| 发布者: rcfans| 查看: 4957| 评论: 0|原作者: SERPENT蛇仔官方
Serpent蛇仔推出用于Viper系列1/8平路车的新款Flow前保险杠。三合一设计,通过在保险杠两侧安装专用垫片,可实现全开、半开和闭合三种空气动力学配置。全开状态时转向效果最低,半开时提供良好的高速转向,闭合状态下保险杠可为车头提供最大的低速转向效果,但会牺牲一部分高速转向。这款具有气动作用的保险杠可安装于所有Viper系列车型,包含调整所需的垫片。产品编号903663 Bumper 1/8 FLOW;903664 Bumper insert set (2+2) FLOW。
设计师/车手Michael Salven先生对于这款产品的Tips :The new bumper is a very nice design, I use it as a tuning aid as well as having just a good bumper which keeps the shape better.Basically you can adjust the steering to your liking. Fully open has the least steering, Semi-open with using the scoops it provides very good high-speed steering. In the fully closed version it has the most low-speed steering which goes a long with a bit less high-speed steering. You will find this bumper very usefull.
http://www.serpent.com/
