Mugen Seiki MBX8T 限量版油动越野卡车
20-5-15 20:54| 发布者: rcfans| 查看: 4349| 评论: 5
Mugen Seiki Racing(日本无限)推出全新限量版工厂专家组装的Mugen MBX8T 1/8 油动越野卡车(Truggy)。由厂车手世界冠军Ryan Maifield和Adam Drake亲自组装和设定,加入了大量原厂Mugen Seiki和Flash Point Racing升级件,包括Flash Point的高性能避震器和差速器。这款MBX8T出厂就已经具备顶尖的装配和设定,可以快速投入各种比赛。
升级件包括
    – E2158 Graphite front upper steering plate: X8/E, X8T/E
    – E2166 Front lower arm plate CFRP: X8T, X8TE
    – E2167 Rear lower arm plate CFRP: X8T, X8TE
    – E2168 Front upright arm (-3): X8/E, X8T/E
    – E2310 Aluminum servo saver arm: X8/E, X8T/E
    – E2420 Chassis weight 40g: X8/E, X8T/E
    – E2602/1 8x16x5 bearings (NMB) (10pcs)
    – E2713 One-piece engine mount: X8, X8T
    – FP2107 FP Aluminum differential cross pins: Mugen
    – FP2149 Lunsford titanium truggy turnbuckle set (5pcs): X8T, X8TE
    – M1020 Ball bearing 6x13x5 NMB (4pcs)
 MBX8T Factory Built 配置
    – Flash Point 10,000 front diff fluid
    – Flash Point 550 cst front shock oil
    – 7.5 Front springs
    – Flash Point 10,000 center diff fluid
    – Flash Point 7,000 rear diff fluid
    – Flash Point 500 cst rear shock oil
    – 7.75 Rear springs
    – Mugen Seiki 40g chassis weight
    – Pre-cut Mugen Seiki/Pro-Line body
    引用 少邢逸 20-5-16 18:54
    引用 曲先生 20-5-16 02:44
    国内啥时候能有
    引用 瞧这俗名 20-5-15 23:17
    毒蛇嘘嘘: 有就没有一款8车比例的汽油
    tlr之前出过一台
    引用 毒蛇嘘嘘 20-5-15 22:40
    有就没有一款8车比例的汽油
    引用 郑直 20-5-15 22:36
    这个得多少大洋啊?
    查看全部评论(5)
