Xray X1 2021 1/10 方程式遥控车
20-12-5 18:24| 发布者: rcfans| 查看: 6942| 评论: 16
Xray正式发布全新2021 X1 1/10电动方程式遥控车,新车全面提升稳定性、可调设定以及提升各种场地的性能表现,在比赛过程中遭遇碰撞后车子能够更好保持战斗力。新设计的尾部球头悬挂系统和铝制中央组件,优化了扭动特性,行走稳定性同时提升,抓地力更好。一片式波箱,增加整体刚性,在车子碰撞过程中更好保护车架、传动和悬挂系统以及悬挂设定,增加了完赛几率。底板使用了新设计,可调轴距,前部采用超窄身设计,抓地力进一步提升。2021的X1也换上了全黑Stealth looking black design外观,金属件使用了电镀黑色处理。
2021 X1新特性:
– Development focused on improving durability, improving adjustability for better performance on a variety of surfaces, and resistance to chassis tweak after impacts
– Tweak free design improvements achieved with a new rear centre pivot mounting system and new pod components
– All-new aluminium centre pivot mounting system improves traction and stability of the car, eliminates tweak issues, and provides new adjustment choices to position the pivot point.
– New one-piece bulkheads achieve maximum durability and eliminate tweak issues after a crash
– Graphite rear upper plate redesigned to integrate with the new bulkheads to improve durability and to eliminate tweak after a crash
– All-new graphite chassis side braces offer three different installation settings to alter chassis stiffness to match track conditions
– New chassis plate updated for the rear pivot and chassis braces
– New rear graphite brace integrates with the new side braces and wing mount
– New front upper and lower arms improve strength and reliability while working with the new front tube system
– New front tube system to adjust the stiffness of the front suspension
– New aluminium front anti-roll bar holder lowers the CG
– Longer front kingpins for greater range of front droop adjustment to improve the steering characteristics
– Stealth looking black design
选购Xray产品欢迎进入
强国模型
    引用 小风车 20-12-18 02:18
    完美 {:鼓掌:}{:鼓掌:}{:鼓掌:}
    引用 西住绫 20-12-6 19:20
    “全车才一个避震?鬼才设计”
    回复:我看你也是个鬼才
    引用 zrt 20-12-6 16:42
    明显是3个减震
    引用 joeway 20-12-6 14:50
    油的就牛逼了
    引用 BladeRunner 20-12-6 12:14
    好车,必买
    引用 ZTK 20-12-5 22:25
    田宫几年前的trf101W看后笑而不语。
    引用 ZTK 20-12-5 22:11
    没有场地
    引用 kaoyan116 20-12-5 21:16
    F1最起码要8个避震加负压(手动狗头)
    引用 走火入魔 20-12-5 20:54
    {:抠鼻孔:}f1一个避震不是很正常吗
    引用 kwy 20-12-5 20:17
    想上1.5T
    哦配合2S电会怎样●﹏●
    引用 callge9you 20-12-5 19:54
    没有视频?
    引用 RayFu 20-12-5 19:50
    别买 一勾油门原地打滑 怎么都没t4好开
    引用 护景枵9 20-12-5 18:32
    我就想看看视频
    引用 滕州boby 20-12-5 18:31
    全车就一个避震?!鬼才设计{:惊讶:}
    引用 沐云之鬼 20-12-5 18:29
    增加完赛几率可太真实了…
    引用 滕州boby 20-12-5 18:28
    不知道说什么,就是!用过Xray的平跑,质量真的杠!
    查看全部评论(16)
