Tamiya田宫模型公布TB-05R详情
20-12-16 22:33| 发布者: rcfans| 查看: 5666| 评论: 11
Tamiya田宫模型公布TB-05R 1/10电动房车详情,作为TB-05的高端型号,R版配备了大量原厂升级件,全面提升战斗力。高效的直轴4WD传动系统,和车架整合在一起的二楼板结构,左右对称的设计,让转向更平均。玩家/车手可以选择两种马达布局,分别是较为稳定的前置和操控较为活跃的后置。TRF避震器、齿轮差速、全车轴承和一体化传动轴都是标准配置,此外,电池安装位置符合IFMAR竞赛规则要求,可以参加各大赛事。产品编号47456。
Option Parts Included:
• Carbon Fiber Reinforced Chassis (Hard)* -NEW PART exclusive to this kit!
• Aluminum One-Piece Motor Plate*-NEW PART exclusive to this kit!
• 39mm Lightweight Rear Swing Shafts (53506)
• Clamp Type Aluminum Wheel Hub (4mm) (53570)
• 06 Module Hard Coated Aluminum Pinion Gear (24T) (54771)
• Aluminum Cup Joints for TB-04 Gear Differential Unit (Long & Short) (54543)
• TB-05 Aluminum Servo Mount (54800)
• TB-05 Aluminum Steering Arms (54801)
• TB-05 Aluminum Steering Bridge (54802)
• 3x50mm Aluminum Turnbuckle Shaft (54845)
• TB-03 Carbon Reinforced A Parts (Gear Case) (54098)
• Aluminum Adjustable Suspension Mount (A) (54881)
• Aluminum Adjustable Separate Suspension Mounts (A) (54884)
• TRF419 Suspension Upgrade Set (54886)
• Soft Stabilizer Set (TA07, TB-05) (54979)
• Stabilizer Rod Stopper (53827)
• 46mm Titanium Coated Suspension Shafts 2pcs. (53851)
• TB-05 Carbon Front Damper Stay (for TRF Super Short Big Bore Dampers) (54846)
• TB-05 Carbon Rear Damper Stay (for TRF Super Short Big Bore Dampers) (54847)
• TRF Super Short Big Bore Dampers+ (4pcs.) (42353)
Features:
• 1/10 scale R/C chassis assembly kit.
• Dedicated aluminum motor plate has a one-piece design that positions the motor 3mm rearwards for a smoother, more intuitive drive.
• The chassis frame is molded in carbon fiber-reinforced resin for enhanced rigidity.
• TRF420 suspension components ensure that your model has top level handling and superior adaptability.
• High performance TRF Super Short Big Bore Dampers come as standard equipment.
• The model comes in a stylish and convenient carry case.
• Requires: Body, motor, tires, R/C equipment (transmitter, servo and ESC), battery pack and charger to complete race spec car.
选购Tamiya产品请进入
http://www.tamiya.cn
    引用 田宮漂移會 21-1-14 01:24
    應該過兩千......
    引用 小风车 20-12-25 04:25
    田公 {:爱你:}{:爱你:}{:爱你:}
    引用 小风车 20-12-23 11:48
    好车呀,一定很好
    引用 大侠好厉害 20-12-17 13:00
    啊这
    啊这
    引用 zwai1999 20-12-17 11:43
    哪有各大赛事?!哪有各大赛事?!哪有各大赛事?!在哪?!在哪?!
    引用 Monsterr 20-12-17 10:20
    还是田宫的特色插头
    引用 玩车一族小飞 20-12-17 09:26
    怎么叫都无所谓,自己玩的开心就好,
    引用 silversol 20-12-17 09:06
    对有钱人来说汽车都是玩具,那田宫的车怎么算?
    引用 dyyzyx 20-12-17 07:56
    我们玩的不都是玩具么?{:奸笑:}{:奸笑:}
    引用 Misaka丨ALD 20-12-16 23:21
    下面有请猴儿给大家表演一个典中典:《田宫的车就是玩具》
    查看全部评论(11)
