TRF501x塑料版!田宫Durga DB01电越
07-9-21 18:17| 发布者: admin| 查看: 3618| 评论: 2
虽然在本届世界赛上颗粒无收,但是在过去的一年来TRF501X还是取得了很多比赛的胜利,包括欧洲锦标赛等。 现在TAMIYA把在501X上获得的经验,移植到廉价的电越上,此车名叫Durga DB01, 基本上就是501X的塑料版,布局基本一致,而且减少零件的数目,方便维护。 车子原配有轮圈轮胎还有540马达。
估计此车又会引起一轮升级件狂潮。
About the Model
- All-new DB01 chassis locates heavy components such as battery and motor near the center for optimum weight distribution.
- Race-proven and reliable 2-belt driven 4WD system is completely enclosed with ABS resin covers to prevent dirt and debris from interfering with drivetrain operations.
- Chassis features integrated bulkheads, which reduces the number of parts and simplifies maintenance.
- Tough ABS resin 4-wheel double wishbone suspension system features the same configuration as the TRF501X and provides a wide range of settings options.
- Brand new buggy body with rear wing is made from lightweight polycarbonate material.
- Wheels, tires, and Type 540 motor are included.
- 2-channel transmitter, ESC, running battery & charger are separately required.
    引用 sensual1 07-9-23 17:37
    xxx-4+trx501x+ta05=db01
    引用 马达王 07-9-22 23:24
    我觉得是TA05 越野版本而已
