田宫DB01 Baldre
08-2-25 08:50| 发布者: jovi| 查看: 3095| 评论: 0
在成功推出DB01系列的第一版Durga之后,TAMIYA计划推出第二版,叫Baldre,基于原有的结构上,搭载了从TRF501X借鉴过来的封闭式双皮带传动系统及其他升级组件。适合大众日常玩耍。
Features:
- All-new DB01 chassis locates heavy components such as battery and motor near the center for optimum weight distribution.
- Race-proven and reliable 2-belt driven 4WD system features equal-length drive belts and is completely enclosed with ABS resin covers to prevent dirt and debris from interfering with drivetrain operations.
- Chassis features integrated bulkheads, which reduces the number of parts and simplifies maintenance.
- Tough ABS resin 4-wheel double wishbone suspension system features the same configuration as the race-proven TRF501X and provides a wide range of settings options.
- Full ball bearings to reduce friction loss for enhanced efficiency.
- New buggy body with rear wing is made from lightweight polycarbonate material.
- Wheels, tires, and Type 540 motor are included.
- 2-channel transmitter, ESC, running battery & charger are separately required.
Requires:
- Radio: 2-Channel with servo(s)
- Battery: 6-cell flat with standard Tamiya connector
- Charger: AC/DC timed or peak for 6-cell battery
- Paint: PS for Polycarbonate/TS for ABS
- Misc. Items: Building and track equipment
