Traxxas Slayer Pro四驱卡车
08-7-4 12:22| 发布者: jovi| 查看: 5022| 评论: 5
Traxxas Slayer是来源于一辆拥有800匹马达的Pro 4™短赛道卡车,参加CORR比赛。Slayer发挥了相同的疯狂精神,除了外形极度像真外,它使用TRX 3.3引擎,速度超过50英里/小时。车子以RTR形式发售。
Features :
  • Scale dimensions and looks of actual short course off-road race trucks
  • Chassis nerf bars absorb impact and support the body
  • Scale front and rear tube-style bumpers
  • 45+ mph top speed out of the box; capable of 50+ mph with optional gearing
  • Larger 150cc Revo fuel tank extends run time
  • Digital high-torque, ball bearing steering servo delivers 125 oz-in & 0.16-sec transit time
  • Aluminum GTR shocks
  • New high-volume dual-stage air filter
  • Tight-handling progressive-2 rockers
  • Titanium-anodized chassis and chassis brace
  • Compact receiver and battery box with integrated personal transponder mount
  • Blue-anodized antenna crimp nut
  • Four channel micro receiver
  • Compact throttle servo mount with air filter support
  • Two-speed forward only transmission
    • Ultra-compact. Fewer moving parts
    • Low rotating mass for quick, high-revving acceleration
    • Constant drive engagement is smooth and instantly responsive
    • Sealed case protects gears & two-speed from damaging debris
    • Autoshifting two-speed is simple, reliable, & easy to adjust
  • Large diameter front disc brake
  • Mirror-polish Resonator™ dual-chamber aluminum tuned pipe
  • High-revving TRX® 3.3 Racing Engine for proven championship-winning horsepower and speed
    • Bigger piston and sleeve delivers extreme power
    • Consistent and smooth throughout the entire power band
    • Straight-through exhaust flow
    • Slide carburetor
    • Knife-edged connecting rod
    • Large aluminum blue-anodized cooling head
    • Super-light piston and rod
    • High-performance ball bearings
    • Backed by Traxxas Lifetime Engine Replacement Plan
  • Torque-Control™ slipper clutch
  • Sealed limited slip front and rear differentials
  • Super-duty driveshafts
  • Sealed pivot ball suspension
  • Rubber-sealed ball bearings
  • Hex hardware
  • TQ™ radio system
  • Scale all-terrain front and rear tires offer superior on- and off-road traction
  • The tires include performance foam inserts and they come pre-glued on satin-finish wheels
  • ProGraphix® multi-colored painted body is available in red, blue, red/black, and blue/black
  • Slayer is backed by unparalleled Traxxas support and parts availability
    引用 PANCZ 08-7-6 02:53
    是很漂亮 哈哈
    引用 corden 08-7-4 22:14
    这个应该不是BAJA1000吧???
    引用 行在风 08-7-4 18:39
    这个帅啊,换上拉力车壳英爱也很像真吧
    引用 wanniyibian 08-7-4 16:51
    我的最爱车行 终于出来了  BAJA1000
    引用 yxg 08-7-4 16:18
    漂亮啊!!!!!!!!
    查看全部评论(5)
