田宫 F103 15周年纪念版
08-10-30 12:01| 发布者: admin| 查看: 4035| 评论: 1
不知不觉,田宫的R/C F103车架已经有15个年头了。为了纪念诞生15周年,田宫推出了全新的轻量化限量版的F103。车子并不是F103 TRF的重新发售,它有新款3.2mm碳纤维底板,及印有特别字样的1.5mm二楼板。还有其他TRF零件,如马达座,舵机座,特富龙摩擦板等等。
Specs
  • 3.2mm Carbon Fiber Chassis w/Anniversary Logo
  • Long Carbon Fiber Upper Deck w/Anniversary Logo
  • Newly Designed Aluminum Servo Mount
  • Carbon Fiber T-Bar Bridge
  • Teflon Friction Plate
  • Carbon Fiber Friction Plate
  • Pre-Attached sponge Tires
  • Height Adjustable Aluminum Differential Housing
  • TRF Damper (F103GT)
  • Carbon Fiber Rear Shaft
  • 4mm Aluminum Lock Nut
  • Aluminum Turnbuckle Shaft
  • High Torque Servo Saver
ELECTRIC KITS REQUIRE:
(unless stated differently above)
  • Radio: 2-Channel with servo(s)
  • Battery: 6-cell flat with standard Tamiya connector
  • Charger: AC/DC timed or peak for 6-cell battery
  • Paint: PS for Polycarbonate/TS for ABS
  • Misc. Items: Building and track equipment
    引用 synoman 08-10-31 19:10
    好喜欢F1的电车
