Losi推出 8ight 2.0 RTR buggy
09-3-27 01:25| 发布者: admin| 查看: 4025| 评论: 0
Losi 8ight 1/8 越野车自推出以来一直很受欢迎,8ight的操控性极佳,操控感受细腻,很多玩家和车手认为驾驶8ight有驾驶电动越野的感觉。 8ight之后推出改良版2.0, 也获得不少好评,为了让更多人可享受Losi越野车的卓越性能,RTR(买回来可行走)的8ight 越野车面世!首选对象肯定是入门越野玩家,装备21级发动机,还装备了Spektrum DX3S 2.4GHz DSM 三通道遥控设备,现在连RTR都装备2.4G DSM遥控设备了,估计以后RC新手都不知道“晶体”为何物。Losi原厂启动台,免去了新手手拉的痛苦,看起来Losi这款RTR算是豪华版的RTR,大家关心的是售价,厂方还没公布价格,希望售价不要太高,造福国内的入门RC玩家。
Features
- Designed with the entry-level racer in mind, the 8IGHT 2.0 RTR is completely assembled and ready-to-run with the chassis, wheels, tires and electronics already installed
- The installed Losi 350 .21-sized performance engine is specifically built for a 1/8-scale off-road buggy and provides an optimal amount of power
- The included Spektrum DX3S 3-channel sport radio system with 2.4GHz DSM technology offers precise control plus the added benefit of integrated telemetry
- The 8IGHT 2.0 RTR includes a Starter Box for simple starting time after time
- The extended-length chassis offers unmatched performance and stability that will be appreciated by novice and expert drivers alike
- A high-capacity 1400mAh NiMH receiver battery is included to ensure longer running times and plenty of power
- Heavy-duty silicone filled differential cases in the front, rear and center increase the driveline durability
- The Sure-Close fuel tank is designed for automatic, positive closure and the pull-handle on the lid offers added convenience
- Large, race inspired heavy-duty brake disks will consistently slow down the 8IGHT 2.0 RTR when needed, even after accelerating to full speed
- The 4mm thick chassis, shock towers, wheel hexes and wheels nuts have been anodized blue for a stylish custom look
- The pre-painted, fully decorated body boasts a custom look with its race inspired scheme designed to match the color anodized chassis
Specifications
Type: Nitro Off-Road Buggy
Scale: 1/8
Length: 19.56 inches (497mm)
Width: 12.13 inches (308mm)
Wheelbase: 12.71 - 12.87 inches (323-327mm)
Weight: 7.125 lbs. (3228g)
Motor or Engine: Losi 350 .21 Buggy Engine
Radio: Spektrum DX3S 3-channel sport radio system with 2.4GHz DSM technology
Batteries: 1400mAh NiMH receiver battery (included)
Kit/RTR: RTR (Ready-to-Run)
Body: Custom screened and trimmed
(32.95 KB)
