Traxxas Slash 和 E-Revo VXL
09-4-13 15:44| 发布者: admin| 查看: 5628| 评论: 0
美国 Traxxas 发布了1/16th  VXL 的Slash 和 E-Revo 新车,将于下月上市. 两台车都是14 英寸长, 正好是1/10车子尺寸的一半. 装备无刷系统,厂方暂时公布的资料不多,但相信这两台车绝对是充满乐趣的产品。
Slash:
E-Revo:
厂方的公布的参数
Slash VXL and E-Revo VXL Features
- Race-winning, F1-inspired Revo® suspension technology and E-Revo integrated chassis design, perfectly optimized for 1/16 scale
- Powered by the Velineon® Brushless Power System
- Traxxas High-Current Connector allows high-capacity battery packs to deliver maximum voltage to the Velineon Brushless Power System
- Velineon VXL-3m Electronic Speed Control
* LiPo, NiCad, and NiMH compatible with two-stage low-voltage detection
* Sport Mode – Forward / Brake / Reverse
* Race Mode – Forward / Brake
* Training Mode™ - 50% Forward / Brake / 50% Reverse (patent pending)
- Velineon 380 Brushless Motor
* High-performance sensorless design
* High-strength Neodymium magnets
* Efficient, high-speed ball bearings
* Precision-balanced rotor
* Gold-plated 3.5mm bullet connectors
- Digital High-Torque Waterproof Micro Steering Servo
- Waterproof, o-ring sealed receiver box
- Traxxas 4-channel micro receiver
- Sealed, silicone-filled differentials—an industry first in 1/16 scale
- Torque-Control™ slipper clutch system
- Telescoping universal-joint driveshafts
- Rubber-sealed ball bearings
- External gear cover with easy slipper access
- Rocker-actuated shocks provide true progressive damping and spring rates
- Threaded-body, oil-filled shocks permit fast, precise preload adjustments and deliver smooth, consistent damping
- Fiber-composite monocoque chassis
- Speed control and receiver are securely fastened to chassis
- Integrated battery compartments with intake and exit cooling vents
- Quick-release battery doors for fast pack changes
- Scale all-terrain front and rear tires offer superior on- and off-road traction
Source: Traxxas [traxxas.com] & Redrc.net
