XRay XT8 升级零件 1
07-6-22 14:02| 发布者: admin| 查看: 1491| 评论: 0
XR-351120 XT8 Alu Chassis - Hardcoated Swiss 7075 T6 (3mm)
The XT8 chassis is CNC-machined from high-quality Swiss 3mm 7075 T6 hardcoated aluminum and is strategically machined in low-stress areas to make it as light as possible without affecting strength or rigidity. Material below the engine, fuel tank, and diffs has been removed to allow for the lowest possible center of gravity. The chassis has optimized weight balance with all parts centralized in the middle for perfect side-to-side weight balance.
All screw holes on the bottom of the chassis are countersunk, allowing for a very smooth chassis underside with no protruding screw heads. The chassis is hardcoated at XRAY’s own in-house fully robotic hardcoating line, ensuring a perfect hardcoated surface.
XR-351308 XT8 Body Posts
Composite bodypost set includes one of each front & rear body posts.  Requires 2 sets for XT8.
XR-351310 Foam Washer for Body Posts (4)
High-quality foam washers for body posts. Set of 4.
XR-352098 XT8 Alu Front Shock Tower - CNC Machined Swiss 7075 T6 (4mm)
CNC-machined front shock tower for XT8 is made from high-grade Swiss 4mm 7075 T6 alum and features XRAY’s stylish black finish with silver edging. The rigid shock tower is strategically lightened to reduce weight without compromising strength. Multiple shock positions (8 per side) allow for numerous shock upper mounting positions.
Shocks can be mounted in multiple different positions, which were thoroughly tested and analyzed both in virtual reality as well as on-track to offer the widest possible range of shock positions. This guarantees sufficient suspension travel and best setup for flat European-style tracks or large bumpy US-style tracks.
XR-352118 XT8 Front Lower Suspension Arm Right
Right arm
Front lower right suspension arm for XT8 made from super-tough high-tech composite material.
The super-long arms provide maximum stability and optimum stiffness to ensure maximum traction under all different racing conditions. These arms allow for superior handling over rough terrain and excellent landing over big jumps.
The smooth lines of the arms ensure they are very easy to clean. Dozens of different suspension arm designs were tested in virtual reality, searching for the best mix of strength, flexibility, and durability. The arms are as thin as possible to provide sufficient flex (thus generating as much grip as possible), while are still reinforced in key areas (e.g., where shocks are mounted to the arms) to ensure that forces from landing big jumps are not transferred negatively to the arms thus avoiding deformation. Front lower arms have the end of the arms narrowed to provide increased steering characteristics and thus better handling.
XR-352128 XT8 Front Lower Suspension Arm Left
Left arm
Front lower left suspension arm for XT8 made from super-tough high-tech composite material.
XR-352138 XT8 Front Upper Arm Right
Front upper right suspension arm for XT8 made from super-tough high-tech composite material.
The super-long arms provide maximum stability and optimum stiffness to ensure maximum traction under all different racing conditions. The smooth lines of the arms ensure they are very easy to clean. Dozens of different suspension arm designs were tested in virtual reality, searching for the best mix of strength, flexibility, and durability. The arms are as thin as possible to provide sufficient flex (thus generating as much grip as possible), while are still reinforced in key areas to ensure that forces from landing big jumps are not transferred negatively to the arms thus avoiding deformation.
XR-352148 XT8 Front Upper Arm Left
Front upper left suspension arm for XT8 made from super-tough high-tech composite material.
XR-352618 XT8 Adj. Turnbuckle M4 L/R 86mm - Hudy Spring Steel™ (2)
CNC-machined M4 adjustable turnbuckles, 86mm length, made from tough HUDY Spring Steel™. Set of 2.
XR-352638 XT8 Adj. Turnbuckle M5 L/R 91mm - Hudy Spring Steel™ (2)
CNC-machined M5 adjustable turnbuckles, 91mm length, made from tough HUDY Spring Steel™. Set of 2.
XR-352662 Steering Ball Joint 5.8mm for M4 (2)
Molded composite steering ball joint for mounting on M4 turnbuckle, attaches to 5.8mm pivot ball. Set of 2.
XR-352663 Relief Steering Ball Joint 5.8mm for M4 (2)
Molded composite relief steering ball joint for mounting on M4 turnbuckle, attaches to 5.8mm pivot ball. Set of 2.
XR-353098 XT8 Alu Rear Shock Tower - CNC Machined Swiss 7075 T6 (4mm)
CNC-machined rear shock tower for XT8 is made from high-grade Swiss 4mm 7075 T6 alum and features XRAY’s stylish black finish with silver edging. The rigid shock tower is strategically lightened to reduce weight without compromising strength. Multiple shock positions (8 per side) allow for numerous shock upper mounting positions.
XR-353118 XT8 Rear Lower Suspension Arm
For left or right
Rear lower suspension arm for XT8 made from super-tough high-tech composite material, may be used on either left or right side.
XR-353151 Relief Rear Upper Outer Camber Link Ball Joint (2)
Molded composite rear upper camber link ball joints fit on the outside end of the camber link turnbuckle of the XT8.  Set of 2.
