Much More Fleta Competition 2 电调
07-9-18 11:56| 发布者: admin| 查看: 1273| 评论: 0
我们赶在产品发布前,就看到照片。 这个电调叫Fleta Competition 2,牌子是MuchMore,实际上是KO Propo生产的。 它只匹配有刷马达,支持高达780A的的持续电流,3120A的瞬时电流,数据够厉害的。 壳体是碳纤维效果,全重18.8g
Specifications:
Control system - PWM control, variable frequency
Max. instantaneous current - 3120A(FET)
Max. continuous current - 780A
Power supply - 4.8 - 8.4V(with 4 - 7cells)
Applicable motor - DC brushed motors
Driving Frequency - 0.9 ~ 12KHz(with 64steps)
Output coltage for receiver - 6V(input 7.2V)
Output current for receiver - 2A(Max. instaneous)
Weight - 18.8gram
