京商发布新电越 Lazer ZX-5 SP
07-10-5 19:13| 发布者: admin| 查看: 1627| 评论: 0
京商发布了他们的最新款1/10四驱电越 ZX-5 SP,也就是不久前世界赛上KY厂队车手所使用的车
这台车有着重新设计的悬挂系统 同时新车壳更能够提供全车的下压力
完全中置的电机和新的电池位置 给车提供了更好的重量分布 更易于操控
这些使得ZX-5 SP成为一款有战斗力的新车
Specifications:
- Straight motor layout is specially designed for centre shaft driven 4WD racing.
- Freely adjustable turnbuckle upper arms are included as part of the double wishbone 4-wheel independent suspension system.
- Equipped with slipper clutch that effectively transfers power as well as protecting the gears from overloading.
- High strength and rigidity of the resin main chassis is reinforced with X-backbone upper deck.
- Features new type triple-cap Pro Shocks. Delivers a wide range of setting adjustment options as well smooth suspension function.
- Choice of three front axle configurations with one-way, ball differential or spool (rigid). One-way is sold separately.
- Rear section equipped with stabilizer.
- Precision universal swing shafts included on front and rear.
- Chassis layout is compatible with either loose battery cells or battery packs.
