Tamiya - TB Evolution 5 MS
08-6-14 22:48| 发布者: admin| 查看: 6503| 评论: 0
Tamiya的顶级直轴电房系列TB Evolution有新产品上市—TB Evolution 5 MS,2.5 mm炭化纤维底板,波箱为快拆方式,同时使用了大量和 TRF416 一致的高端零件,在皮带车大行其道的现在,TB5 MS还是极有竞争力! 6月21号上市。
To new territory of shaft 4WD
Aluminum make rear upper deck
Upper deck rear section divided system of aluminum make. Rigidity is raised, operating efficiency such as gear exchange is raised.
Steering wheel
The steering system of the center support type which adopts the know-how of TRF416. Also fine control of Ackermann’s is possible.
Upright
Approximately as for upright 1050 bearing specification which is similar to TRF416. You lighten abnormal play, correspond to high load.
[rowadetsuki]
Cutting motor cooling was administered to 2.5mm thick carbon make [rowadetsuki] which sets the rear somewhat widely.
Suspension mount
The aluminum suspension mount for TRF416 which increased the precision in toe angle equipment to front and back.
Front one way
At the time of advanced motor use and low the front one-way unit which shows the effect in the grip road surface standard equipment.
Main Equip Parts - Aluminum motor mount - Aluminum upper blurring chair - Aluminum spur holder - Aluminum steering wheel center mount - Aluminum steering wheel bridge - Aluminum steering post - Aluminum steering wheel spacer - Aluminum steering wheel arm - Center cup ●44mm swing shaft ●TRF special damper - One somatotype [arumirowabarukuhetsudo] - Aluminum upper bulkhead - Aluminum propeller shaft - Aluminum diff. joint - Short reversible suspension arm - Front and back stabilizer
Specification - Chassis total length: 364mm - Chassis full-width: 188mm - Wheel base: 257mm - Tread: Approximately also 160mm
