Kyosho Mini Z MR-03W-RM BCS Ferrari F430 Challenge No.28
09-12-28 05:05| 发布者: admin| 查看: 2275| 评论: 0
32804-01l-500x294Kyosho(京商)的MR-03 蚊车上市已经有一段时间,越来越多的玩家加入MR-03新车的行列,Mini-Z的MR-02、AWD、MR-015都是非常成功的迷你型遥控车产品,MR-03车架是继承了之前多代Mini-Z后开发而成,加入了最新的RC技术,例如2.4G、数码舵机等,2010年这款MR-03W-RM BCS带 Ferrari F430 Challenge No.28车壳的03将会上市,相信随着MR-03产品线不断丰富,必定有更多的蚊车玩家选用MR-03。更多照片在本文内。 The difference of this machine will be noticed at the very first turn. The suspension stroke and camber change work in unison in the innovative front suspension to accurately trace the road surface while the adoption of a coreless motor in the newly designed digital steering servo has the model driving like its on rails with a light touch steering feel that brings the car back smoothly into line. In addition to the same low C of G from the MR-02, the narrow body styles of the MR-015 can be fitted due to the lightweight concentrated design. In fact, the MR-03 is compatible with all body styles from the MINI-Z racer series, which is perhaps the most comprehensive tribute to automotive excellence in R/C. Combine the MR-03 with your favorite car body and you have the finest radio controlled model available in style and performance. *Optional parts maybe required when fitting some bodies to some chassis types. Available: February 2010
