Kyosho MiniZ MR-03N 2.4GHz Chassis Set JSCC Edition
10-5-28 15:36| 发布者: admin| 查看: 3398| 评论: 0
32720-01lKyosho 的Mini-Z MR-03有新款车架发布,装备多款升级零件的 JSCC Cup Limited Edition MR-03 chassis,这是限量版车架,玩家只需配上喜欢的车壳,就能立即享受MR-03带来的快感!悬挂、转向性能大幅提升,这不是一辆简单的MR-03,详细资料在本文内。Just add your favorite body and hit the race track. The all new MR-03 series race ready chassis set is outfitted with only Kyosho quality option parts like a precision ball bearing set, ball differential set, rear oil filled shock set, carbon fiber friction shock set, plus tons more. Get the real race experience right out of the box with the new MR-03 JSCC Cup Limited Edition chassis set! The difference of this machine will be noticed at the very first turn. The suspension stroke and camber change work in unison in the innovative front suspension to accurately trace the road surface while the adoption of a coreless motor in the newly designed digital steering servo has the model driving like its on rails with a light touch steering feel that brings the car back smoothly into line. In addition to the same low C of G from the MR-02, the narrow body styles of the MR-015 can be fitted due to the lightweight concentrated design. In fact, the MR-03 is compatible with all body styles from the MINI-Z racer series, which is perhaps the most comprehensive tribute to automotive excellence in R/C. Combine the MR-03 with your favorite car body and you have the finest radio controlled model available in style and performance. *Optional parts maybe required when fitting some bodies to some chassis types. Available: June 2010
