Kyosho Mini-Z MA-010 AWD DWS-Chassis ASF
10-10-12 16:28| 发布者: admin| 查看: 6104| 评论: 0
30590_1KYOSHO推出全新的Mini-Z Racer蚊车, MA-010 AWD Chassis DWS ASF。这个特别版本的AWD使用全新的尾部悬挂 (DWS, MDW-100),搭载2.4G系统,KO数码舵机等高性能组件,详细资料在本文内。introduces a new Mini-Z Racer with permanent four-wheel drive in 1:24 scale: the MA-010 AWD Chassis DWS ASF. This Special Edition is equipped with the new double wishbone rear axle suspension (DWS, MDW-100). The vehicle has a motherboard with wireless technology in 2.4 GHz. Delivery will be made without the transmitter. For the operation, a Kyosho Perfex KT-18 (item number 82 001) and the right wheels and a body is required. In the receiver unit of the Racers a FET controller is integrated, which drives the electric motor is very sensitive. For the implementation of the steering commands provided by a KO PROPO Digital Servo from high positional accuracy and high holding torque.
