Losi Ten SCTE - 4WD短途卡车
11-1-24 21:29| 发布者: admin| 查看: 7191| 评论: 0
Team Losi推出新款1/10 TEN-SCTE 4WD Short Course truck(短途卡车),这款电动卡车最大亮点是使用了中差速,合金底板,大容量避震(12mm),Eclipse短卡轮胎,看起来这辆SC是高性能车架,无刷+锂电是肯定支持的,配备了中差,相信行走性能有质的飞跃!
Take your passion for the short course in a whole new direction. The Losi 1/10-scale TEN-SCTE 4WD Short Course Rolling Chassis is unlike anything you’ve ever seen. With oversized 12mm anodized threaded shocks, Eclipse Short Course truck tires, and lightweight black anodized aluminium chassis, the TEN-SCTE’s performance is unforgettable.
SPECIFICATIONS
Length: 524mm (21.34 in)
Width: 295.8mm (11.65 in)
Wheelbase: 334mm (13.15 in)
Weight: 3.06 kg (6.75 lb)
Tyre Type: Eclipse SCT
Body: Clear Polycarbonate Buggy
Shock Type: Aluminium, Coil-over, oil-filled
FEATURES
- Functional mud flaps with Losi logo
- Oversized 12mm anodised, threaded shocks
- 12mm wheel hexes
- Secure battery straps
- Battery tray accepts multiple types and sizes of packs
- Heavy-duty, 4mm tie rods with captured ends
- Beadlock-style SCT wheels with rings
- Front and rear sway bars included
- Eclipse Short Course truck tyres
- Secure radio box to protect the receiver
- Simple adjust, aluminium motor mount
- Lightweight black anodised aluminium chassis
REQUIRED TO COMPLETE
- 550-sized Brushless System (Motor and ESC)
- 1/10-scale Steering Servo
- 2S LiPo Battery Pack and Charger
- 2-channel Radio System
- Polycarbonate Paint
LOSB0127
