Picco推出新款TORQUE Edo Modified油动1/8平路车引擎,turbo盘顶、7ports、14mm turbo机轴、14mm瑞士轴承、轻量化散热顶,马力达2.8p,属于高性能竞赛级发动机.
Highlights • 7 Ports + 2 by pass hard chromed liner • Piston CNC machined from billet • 14mm turbo shaft • Knife edged aerodynamic connecting rod • Separate large size finned turbo combustion chamber insert • 14mm Swiss quality main bearing • Super lightweight cooling head • Composite slide carburetor • 7.0mm, 8.0mm and 9.0mm venturi inserts Technical datas • Displacement: 3,49cc • Bore: 16,26mm • Stroke: 16,80mm • Output: 2,8hp @ 37,000rpm • Weight: 335gr Source : novasy.net |
