Team Associated RC8.2 Factory Team Kit
11-7-21 01:02| 发布者: admin| 查看: 6421| 评论: 10
Team Associated推出RC8.2 Factory Team kit越野车,新车加入了一些升级组件。全新的Factory Team 加长3mm 7075高强度底板,使用了新底板后车架的重量分布更佳,操控也进一步提升。16mm大容量避震器,低重心油压架等都被用在新车上。随车还包含了JConcepts Punisher 车壳和Illusion定风翼,看来AE这款新车是完全为竞赛而推出的高性能产品!
Features
- Factory Team 3mm lengthened 7075 hard-anodized chassis
- Newly designed suspension arms
- Factory Team 16mm “Big Bore” hard-anodized threaded shocks
- Factory Team 5mm 7075 aluminum low-CG shock towers
- Factory Team 7075 blue aluminum lower suspension mounts
- Factory Team 7075 blue aluminum steering knuckles
- Factory Team 7075 aluminum axles and center drives
- Factory Team 7075 blue aluminum one-piece top plate
- Factory Team lightweight spur and ring gears
- Factory Team lightweight diff outdrives
- Factory Team aluminum steering posts
- CVA boots on center and rear drive joints
- Heatsink brake rotors front and rear
- New low center-of-gravity wing mount
- JConcepts Punisher Body and Illuzion wing included
- Molded composite radio tray includes optional forward-placement
- battery box for increased steering
- Molded composite front and rear chassis braces
- Tough steel-alloy shock standoffs
- Factory Team 83mm “big” wheels included
- Aluminum clutch shoes
- 4.30:1 ratio gearboxes for maximum punch
- Caster blocks adjust 14, 16, or 18 degrees with molded inserts
- 3.5mm light CVA drivetrain with full ball bearings
- Factory Team shock and differential fluids included
- Mud guards
http://www.redrc.net/wp-content/uploads/2011/07/RC82FactoryTeamChassis.jpg
http://www.redrc.net/wp-content/uploads/2011/07/RC82FactoryTeamFrontShockTower1.jpg
http://www.redrc.net/wp-content/uploads/2011/07/RC82FactoryTeamFrontSuspension.jpg
http://www.redrc.net/wp-content/uploads/2011/07/RC82FactoryTeamRearSuspension.jpg
http://www.redrc.net/wp-content/uploads/2011/07/RC82FactoryTeamShocks.jpg
Source: Associated [rc10.com]
    引用 wyshjhbna 11-7-23 20:55
    shai!!!!!!!!!
    引用 武汉螃蟹 11-7-21 19:31
    太帅了挖槽
    引用 reiyagami 11-7-21 15:32
    除了要等货其他还有什么可以挑剔的520啊 tmd便宜了。。。。rc8系列都是公制的
    引用 tw8180 11-7-21 15:09
    英制还是公制?
    引用 reiyagami 11-7-21 14:54
    520刀啊!!!!!!!擦
    引用 zhukenda123 11-7-21 12:40
    520$的零售价 太亲民了... AE雷虎的定价还算比较厚道
    引用 ·~昶、~~ 11-7-21 11:26
    好车啊~~
    引用 reiyagami 11-7-21 08:57
    这辆 除了后hub和前后支撑 其他都op了 包括轻量化接杯这样的毒物 全新的摆臂。油压架、防倾杆。底板 准竞赛级别的东西。。。
    引用 lx0836 11-7-21 08:52
    避震的固定方式跟SC10 4X4一样了 看样子 螺丝的规格也因该一样~~~~~~~~~
    引用 颜俊文 11-7-21 08:10
    靓到爆镜·········沙发
    查看全部评论(10)
