Mugen MTX-5油房实车照
11-7-26 23:01| 发布者: admin| 查看: 7340| 评论: 6
日本Mugen Seiki发布了他们的新一代1/10 200mm油房MTX-5实车照和公布了新车的特性。MTX-5的CAD设计图出现在今年2月德国纽伦堡展览会上,厂方公布了实车照意味着离量产不远了,然而至今也没有公布MTX-5的上市日期,真的让fans们望穿秋水!
Technical Information:
- Aluminum front/rear bulkhead
- Special radio tray module for both lay down servos and receiver including mountable receiver box
- New system for faster belt change
- New fuel tank mounted from upper side
- New front upright system that easily changes the king pin angle by option parts
- Aluminum middle shaft
- New rear brake system
- Fast change roll center
- Fast change steering ackerman
- New front bumper
- Adjustable weight balance
- Lightweight gear differentials
- New internal gear ratio
- New anti-roll bar system
- New clutch system
http://www.redrc.net/wp-content/uploads/2011/07/MugenMTX5-1.jpg
http://www.redrc.net/wp-content/uploads/2011/07/MugenMTX5-3.jpg
http://www.redrc.net/wp-content/uploads/2011/07/MugenMTX5-4.jpg
http://www.redrc.net/wp-content/uploads/2011/07/MugenMTX5-5.jpg
Technical Data:
Length: 380mm
Width: max. 200mm adjustable
Wheel Base: 257.5mm~260.5mm adjustable
Tread (F/R): 173mm/169mm
Front Caster Angle: 6.4°~13.8° adjustable
Gear Ratio: 1st. 7.24:1 / 2nd. 4.69:1
http://www.redrc.net/wp-content/uploads/2011/07/MugenMTX5-6.jpg
http://www.redrc.net/wp-content/uploads/2011/07/MugenMTX5-7.jpg
http://www.redrc.net/wp-content/uploads/2011/07/MugenMTX5-8.jpg
    引用 86841991 11-7-27 14:47
    kiro: 733根本没资格和MTX5相提并论
    没听说过
    引用 kiro 11-7-27 14:08
    晴忝尛豬: 733的大敌来了。。。。
    733根本没资格和MTX5相提并论
    引用 小灰灰 11-7-27 12:39
    太好了 MTX 5要出了`` 可惜啊 没有想像中的那么神奇 不过前转向 设计还是感觉还是不错的``
    引用 7598523qq 11-7-27 11:06
    NT1怎么办
    引用 bjliuxu 11-7-27 00:56
    有比我还无敌的,都来报道了,哈哈 做一个板凳
    引用 晴忝尛豬 11-7-27 00:45
    733的大敌来了。。。。
    查看全部评论(6)
