Team Orion 短卡无刷马达
11-10-7 00:43| 发布者: admin| 查看: 6786| 评论: 4
Team Orion推出新款Vortex VST SC 550 Pro无刷马达。专为短途卡车(Short Course)设计,550级有感无刷,马达的设计能有效降低温度,提供4.0,4.5和5.0三个型号供玩家选择。
• 550 size sensor brushless racing motor
• Optimised for Short Course Truck applications
• Rebuildable 2 piece motor can design
• Optimised sensor – rotor – stator positioning for improved efficiency
and lower heat build-up
• New stack design for improved efficiency
• New cooling vent design for improved cooling
• Extra thick front plate for better stability and cooling
• Extra thick solder posts for improved contact and stability
• Removable sensor plate with high speed ballbearing
• New design gold plated wind ring
• Reduced vibrations
• Designed in Switzerland
#ORI28240 Vortex VST SC 550 PRO 4.0
Technical Specifications
  • Voltage 7.2-11.1V
  • RPM/7.4V 33‘400
  • kV 4‘600
  • Power/W 800
  • Current/A 80A
  • Efficiency 86%
  • Magnet material Sintered
  • Sensor/sensorless Sensor
  • Adjustable timing Yes
  • Poles 2
Dimensions
  • Weight 265g
  • Length 65.9mm
  • Diameter 35.8mm
  • Shaft length 20.8mm
  • Shaft diameter 5.0mm
#ORI28241 Vortex VST SC 550 PRO 4.5
  • Voltage 7.2-11.1V
  • RPM/7.4V 31‘000
  • kV 4‘200
  • Power/W 750
  • Current/A 70A
  • Efficiency 87%
  • Poles2
Dimensions
  • Weight 265g
  • Length 65.9mm
  • Diameter 35.8mm
#ORI28242 Vortex VST SC 550 PRO 5.0
  • Voltage 7.2-11.1V
  • RPM/7.4V 27‘700
  • kV 3‘700
  • Power/W 700
  • Current/A 60A
  • Efficiency 88%
  • Poles 2
Dimensions
  • Weight 265g
  • Length 65.9mm
  • Diameter 35.8mm
    引用 8deepwater 11-10-7 15:24
    怎么没见有人用team orion
    引用 sandyhalo 11-10-7 09:57
    Poles 2。。。。。
    引用 邦德座驾 11-10-7 02:45
    骚货越来越多,钱包越来越瘪。
    哎~
    引用 lijiang0620 11-10-7 02:19
    不密封的?怕怕。。。。。。。。
