Muchmore 推出新产品
11-11-2 13:53| 发布者: admin| 查看: 4606| 评论: 3
Muchmore 推出新产品,包括世界赛版本II EVO 12v直流输出电源和焊接座。其中直流输出电源最高支持24A,峰值30A/0.5秒,内置散热风扇和过载保护,有黑色和蓝色两种款式供玩家选择。新推出的焊接座让电车玩家轻松焊接马达、电变和各类插头。
The Muchmore Racing Power Master World Edition II EVO 12V DC Power Supply incorporates even more racer-requested features, for the ultimate in performance and convenience!
• Produces 24 amps of constant current with a peak of 30A/0.5 seconds
• The built-in cooling fan runs only when needed
• Equipped with overload short circuit protection
• Features an easy-to-read blue LED power status indicator
• Compact (5.3 x 5.7 x 2 in) and lightweight (1.6 lb)
• Encased in sturdy anodized aluminum, in black or blue
焊接座
With the Muchmore™ Racing Soldering Station, modelers can concentrate on soldering without worrying about keeping their connectors steady!
• Handy jig holds components securely so modelers can focus on soldering
• Eight different marked holes (2.0-5.0 mm) hold male and female connectors upright
• A clamp with thumbscrew holds an ESC or Deans® connector in place
• Made of machined black anodized aluminum with no-slip rubber feet
• Takes up virtually no space on the workbench!
    引用 aetc3 11-11-3 10:26
    卖的就是个壳子,,这焊接架不知道着么用的
    引用 nankey 11-11-3 04:12
    muchmore的电源垃圾的1b那啥……拆开后山寨都不如,上示波器直接爆表,棒子的心态始终有问题的
    引用 蜡包 11-11-2 15:44
    价格高得离谱,扯淡吧就
