AE RC10TC6.1 厂队版
11-11-24 00:19| 发布者: admin| 查看: 14438| 评论: 6
Team Associated推出RC10TC6.1厂队版新一代电动房车。该车在上周亚洲电房系列赛(ATS)上首次公开亮相(由车手Juho Levanen驾驶,获得亚军佳绩)。基于TC6的成功,AE开发出TC6.1新车,除了行走性能的提升,设计师以提升操控和调教简易性为目标进行开发。使用了窄身底板,根据现在流行的锂电和无刷电子设备优化了车架的重心分布,从而提升操控性能!
新的caster组件和尾hub,让玩家可快速调整以适应各种场地。全新的H.D.R.C. (High Definition Roll Control) 系统,将防倾杆技术提升到一个新高度,通过更换链接组件来改变车架的滚动性能!轻量化尾差速、VCS3避震器、多角度可调的转向组件等新零件和设计被用在AE这台新车上。AE宣称这是划时代的遥控电动房车,是电房未来发展趋势!
Features
- Updated suspension arms for increased stiffness and strength, as well as finer shock adjustments
- Hubs and caster blocks use integrated inserts for adjustable caster and toe angles
- H.D.R.C. (High Definition Roll Control) system
- Lightweight rear gear diff for maximum performance and minimal maintenance
- Front spool with replaceable composite outdrives
- Offset arm mounts help increase durability and minimize shims between mount and bulkhead
- Ultra-narrow chassis layout optimized for Lithium Batteries and Brushless Motors
- Symmetrical bulkhead layout minimizes spare part cost
- Multi-position steering system to fine-tune Ackermann/steering rates
- VCS3 Shock with hard-anodized threaded shock bodies
- Titanium turnbuckles with new ballcup eyelets for easy access to ball stud
- 16 precision ball bearings
- Cross-compatibility with TC6 chassis components
1234下一页
    引用 Vengaboylichao 12-8-25 19:10
    ae也是用的yfs的螺丝啊
    引用 reiyagami 11-11-24 15:56
    齿差要入
    引用 qazzyl 11-11-24 13:06
    好车,看过说明书,可调性多的有点变态
    引用 长风大侠 11-11-24 12:23
    shi995800: 想看车架照~~
    你点文章右下角的【下一页】就可以看了。
    防倾杆设计有点新意,中间那个轴应该还要加轴承哦?
    引用 bo68674 11-11-24 10:31
    齿差!!!!
    引用 shi995800 11-11-24 09:38
    想看车架照~~
    查看全部评论(6)
