Reds Racing推出升级版本的M7T 1/8平路车引擎,名为M7T V1.1。升级了化油器,使用了较短的油针以适合各款1/8平路车车架,加入了中速油针,油针调教可更精准。机壳也是新设计,安装到车架更方便。
Category | 1/8 on road | Displacement [cm^3] | 3,5 | Bore [mm] | 16,26 | Stroke [mm] | 16,8 | Inlet ports | 7 | Outlet ports | 3 | Front ball bearing dimension DixDexS [mm] | 7x19x6 | Front ball bearing features | metal screen | Rear ball bearing dimension DixDexS [mm] | 14x25,4x6 | Rear ball bearing features | ceramic balls | Carburetor diameter [mm] | 7,8,9 | Carburetor setting | 2 needle | Glow plug | turbo 7 | Weight [g] | 310 | Cilinder system | ABC | Exaust type | rear | Recommended pipe | EFRA 2033 / 2069 | Recommended fuel | 25% nitro, 8-9% oil | Break-in fuel | 12% oil |
