XRAY T3 Solid Axle Driveshaft Adapter – HUDY Spring Steel
11-11-30 11:48| 发布者: admin| 查看: 3124| 评论: 1
Xray给他们的T3电动房车直轴推出升级轴套,使用Hudy高性能弹簧钢制造!强度和耐用度大大提升,适合T2 008, T2 009, T2R PRO, T3, T3R, T3 2011,和T3 2012使用。
#305137 Solid Axle Driveshaft Adapter – HUDY Spring Steel™ (2)
• CNC-machined drive shaft adapters for #305184/305188 XRAY Composite Solid Axle, made from HUDY Spring Steel™
• direct replacement for the stock composite versions
• increased strength and lifespan
• modular design of solid axle allows for easy removal and servicing
• internal slots key to drive shaft pins require use of driveshaft blades #305241 (included), enabling direct power transfer to the wheels
• precision machined with highest tolerances using premium fully-automatic German CNC-machines
    引用 zshua6 11-11-30 17:05
    价格应该很贵吧!弹簧钢可不好做..
