Schumacher Cougar SVR越野车
12-7-1 13:51| 发布者: rcfans| 查看: 8953| 评论: 8
英国Schumacher公司推出新款Cougar SVR 2WD电动越野车。基于已经取得成功的Cougar车架研发而成,特别适合泥泞和低抓地力赛道竞赛使用。新车装备了全新的传动系统,马达安装位置被后移,车架的重量分布也进行了优化,力求获得最大的抓地力!无论是室外越野路面、草地还是室内赛道Cougar SVR都能胜任!
Cougar SVR SpecificationEquipment Needed
  • 2 Channel Radio
  • Motor
  • Servo
  • Electric Speed Control
  • Tyres
  • Motor Pinion
  • Lipo Battery
Power Source:ELECTRIC
Model Type:2WD, OFF ROADCOMPETITION
Length:370mm
Wheelbase:267mm
Width:240mm
Top Speed:40 MPH+
Features
  • NEW Rear motor, three geared transmission - Excellent grip on low traction circuits..
  • NEW CVA style driveshafts - Increased drive.
  • NEW Forward cab shell - Modern look that offers improved high speed steering.
  • NEW Moulded chassis sides - Fantastic dirt seal with no handling compromise.
  • NEW Longer front wishbones - Improved corner speed.
  • NEW Alloy chassis - low centre of gravity for LiPo batteries.
  • NEW Stronger front bulkhead and bottom plate - Its even tougher.
  • NEW Large front/rear battery position adjustment - Allows weight distribution tuning for each track.
  • NEW Gear differential option available.
  • NEW Carbon Fibre Anti-Squat plates 0o - 3o.
  • NEW Quick access differential.
  • NEW Material strengthened wheels.
  • Heavy duty, big bearing differential - Small diameter, lightweight unit offering low rotating mass.
  • 24 piece “Red Seal” ball bearing set - Gives silky steering and transmission.
  • Large transmission bearings - Strong and reliable.
  • Super strong steering levers, unique constant radius steering system  -  Offers true ackermann and linear steering response.
  • Easy to assemble, rigid wing mount system - Stronger, with less wing flex.
  • Moulded gear cover - Better spur gear protection.
  • “Super cool” Alloy motor plate - Larger surface area and greater thickness offers better cooling and rigidity.
  • Rear wishbones - Offers more lower position shock mounting options.
  • Rear anti-roll bar - Better handling.
  • Accepts either stick, saddle or shorty lipo batteries as standard  -  For superb versatility.
  • Pro spec 13mm big bore shocks with titanium nitride shafts, CNC machined pistons with recessed ‘e’clips, threaded collars, twin O ring sealing and diaphragm volume compensation.
  • PTFE coated shock bodies - Hard, and super smooth shock action.
  • All CNC machined internal geared transmission - Super quiet and efficient.
  • Excellent centre line balance  -  Great control for all track surfaces.
  • Adjustable bushed pivot control system  -  Super smooth, multi position suspension action.
  • Fully optimised suspension geometry  -  Fast, consistent handling.
  • Maximum dimension rear wing - Superb airflow control, offering maximum down force.
  • Black 7075 T6 alloy motor plate and lower diff mounts.  -  Strong yet lightweight.
Prototype model shown, details may vary.
12下一页
    引用 super_弟 12-7-7 19:30
    貌似有一个和维卡一样的设计哦~~~就是拉杆调节倾角
    引用 xiaozi2212 12-7-4 11:02
    好多套套
    引用 bo68674 12-7-3 08:42
    又回到大路上了!
    引用 DRaider 12-7-2 20:08
    bucuo
    引用 crusaderlyf 12-7-2 11:28
    RC高手: 这个牌子千年出一台车
    SC cougar sv发售不到3年已经推出了3台2wd电越和一些套装,是这个2wd电越里算更新最快的厂商之一,您只是不了解而已
    引用 RC高手 12-7-2 09:05
    这个牌子千年出一台车
    引用 炎焱 12-7-1 20:00
    看起来不错~
    引用 luckpolar 12-7-1 17:37
    wow!~ 好新颖的设计哦!~
    查看全部评论(8)
