Team Orion Advantage Touch Pro充电器
12-10-11 10:53| 发布者: rcfans| 查看: 12557| 评论: 5
Team Orion推出Advantage Touch Pro充电器,最高支持12A充电和20A放电。150W充电电路,6S锂电都可以实现快速充电。400×240彩色触控显示屏,多重错接保护系统。可通过USB接口对充电器进行升级和语言更换,可选温控检测组件和HPC高精准充电系统(High Precision Charging System)提供最佳的充电和平衡处理。
Features:
- Microprocessor controlled advanced digital circuit
- Input Voltage: 11-18VDC
- Screen: Spectra TFT 400×240 color touch screen
- Functions: charge, discharge, storage, cycle, balance
- Charging Capability: LiPo/LiFe/LiIon 1-6 cells, NiMH/NiCd 1-15 cells, Pb 2-20V
- Charge Current: adjustable 0.1-12A (variable with number of cells, 150W max)
- Discharge Current: adjustable 0.1-20A (variable with number of cells, 100W max)
- Charge and discharge curve graphic engine
- Charge Assistant
- ATTS Advanced Touch Technology Software
- HPC High Precision Charging System
- Cycle modes: C->D, D->C, D->C->D
- Unique 4-in-1 Balancing Board included (XH, TP/FP, EH, HP/PQ)
- Balancing: adjustable on/off
- Advanced Stand Alone Balancing
- Discharge Cut-off voltage: adjustable
- Multi-Protection System: Input and output reverse polarity protection
- Multi Language Menu (updatable via USB port)
- Charge and discharge data storage for later review
- Adjustable automatic delta-peak charge cutoff
- Temperature monitoring and cut-off (optional)
- TRX-, Deans-, Tamiya-, Crocodile Clips, BEC- and Futaba- charging cables
- Dimensions: L170xW158xH45mm
- Weight: 840g
    引用 陈威 12-10-12 21:49
    电饭煲,有木有???
    引用 DMAX 12-10-12 18:48
    看第二张,明明就是个PC 电源嘛,哈哈。
    引用 ACGFANS 12-10-12 13:08
    这个是路由器 好不
    引用 辰哥 12-10-12 07:15
    我觉得像便携式打印机 小猪
    引用 晴忝尛豬 12-10-11 19:57
    ..........这货好像离子空气清新器唉...............
    查看全部评论(5)
