Serpent S120 LTX
12-10-29 13:28| 发布者: rcfans| 查看: 4882| 评论: 0
Serpent(蛇仔)推出S120 LTX新款1/12电动平路车(12仔),延续使用Link-Tube系统,底板和油压架等组件都是全新设计。更低重心和更稳定的操控感受(减少车子侵略性反应),相信新车战斗力有进一步提升。 ->点击这里进入Serpent品牌专区查阅详情
Following parts are new - Carbon 2.0mm bi-directional woven chassis –plate in symetrical design - Carbon 2.0mm bi-directional motorpod plate - Carbon 2.5mm topdeck, shocktower and tube topplate The new parts are also available separate to update your current car.
The other strong points of the Serpent S120 remain:
- fully adjustable front end with alu suspension blocks in T6 alu,
- strong wishbones ,
- springloaded steeringblocks with easy adjustable pre-tension with allen key;
- supersmooth fully adjustable coated aluminium shockabsorber with foam,
- 7075 T6 rear end parts for the motorpod,
- lightweight and very durable ball differential with aluminum shaft,
- foam bumper and durable body-posts, - coated aluminum tubes, - springloaded nylon side-links, - battery can be mounted in length or width - kits have latest versions diff- and wheel adaptors Following parts are new - Carbon 2.0mm bi-directional woven chassis –plate in symetrical design - Carbon 2.0mm bi-directional motorpod plate - Carbon 2.5mm topdeck, shocktower and tube topplate
411271 Chassis carbon S120 LTX 411272 Lower pod plate carbon S120 LTX 411273 Topdeck carbon S120 LTX 411274 Link top plate carbon S120 LTX 411275 Shock bracket carbon S120 LTX 411276 Cross brace carbon S120 LTX
