Tamiya TRF417 V5套装
12-12-4 14:05| 发布者: rcfans| 查看: 7799| 评论: 5
Tamiya(田宫)推出TRF417 V5套装(Premium Package Chassis Kit)。这款417产品配备了新的碳纤二楼板、一片式马达座、通气型(aeration)避震(可提高抓地力)等升级零件。3.5mm厚度新款头尾碳纤油压架和新的传动轴杯都是标准配置。417在今年荷兰电房世界赛上由车手Jilles Groskamp驾驶勇夺世界冠军,Tamiya TRF41X系列电房已经夺得过5个世界冠军头衔 (2002, 2004, 2008, 2010, 2012),战斗力超群!Tamiya厂方宣称41X系列可能是这个星球上最强电动房车!
Special features unique to the TRF417WX:
  • Newly designed carbon fiber upper (2.0mm thick) and lower (2.25mm thick) decks feature refined shapes to provide optimum roll flexibility.
  • Newly-designed one-piece aluminum servo mount is secured to the chassis by one side (inner side) only so as to not jeopardize chassis flexibility.
  • Newly-designed aeration dampers help maximize traction.
  • Front and rear carbon fiber damper stays (3.5mm thick) have redefined damper attachment positions.
  • Front direct coupling is equipped with steel cup joints and coupled with Double-Cardan drive shafts to provide efficient, smooth power transfer.
  • Rear gear differential features steel diff joints and swing shaft protectors.
    引用 再说不见 12-12-6 09:36
    蓝色金属!
    引用 pmpiyw 12-12-4 18:39
    我喜欢这样霸气的宣传
    引用 ss_aa 12-12-4 18:30
    避震帅了~
    引用 凡阿特 12-12-4 17:59
    不是可能,是肯定
    引用 zhy 12-12-4 16:13
    我的最爱····
    查看全部评论(5)
