RC4WD 1/14 4×8 Armageddon自卸卡车
13-2-23 18:37| 发布者: rcfans| 查看: 10567| 评论: 25
RC4WD推出1/14 4X8 Armageddon液压自卸卡车。超高像真度,可通过遥控锁定的尾轴,1000kV无刷马达推动的液压泵。轻松“运输”沙石、沥青、木块等材料。CNC工艺金属组件,出厂已经装配完成的车架,两段变速都是标准配置。喜欢遥控卡车/拖车的fans不妨考虑RC4WD这款新产品。
Features:
  • Hard plastic European style front Cab
  • Full metal 2 speed transmission (Planetary gears)
  • European style V shape dumper
  • Full electronic sound system (engine start, idle and more)
  • Transfer case (billet alum)
  • Scale fuel tank (billet alum)
  • Super scaled leaf spring suspension setup
  • Scale rims (billet alum)
  • Remote lockable rear axle (locking differential)
  • Hard plastic rear axle housing
  • Steel scale drive shaft
  • Realism front cab latch
  • Retractable steel ladder
  • Molded functional fuel tank (filled with hydraulic oil)
  • Automatic trailer gate (do not attempt to open it by hand)
  • Rear light guard (protect against rock)
  • Scale light bucket (fit 3-5mm LED)
  • Recommended payload: 16kg/35lbs
  • Maximum lift power: 42kg/92lbs
  • Rear dump is powder coated white
  • Scale fire extinguishers and spare wheel/tire
  • Cylinder maximum thrust: 109kg/231 lbs
  • Brushed driven motor
  • 1000kV Brushless motor-driven micro hydraulic pump
  • Basic 6 channel 2.4Ghz radio
  • Basic 60T 540 motor
  • Gray/Black (Front Cab) and white (dump) color finish
  • Powder coated finish (dump)
  • 30 days limited warranty
  • This product is professionally pre-assembled
Specs:
Length: 687mm/27inch
Width: 186mm/7.3inch
Height: 262mm/10.3inch
Weight: 8kg/17lbs
Theoretical load: 15kg/33lbs
Load total mass: 23kg/50lbs
First gear 1:16, second gear 1:4 (Transmission)
What’s included:
  • 1x 1/14 4×8 Armageddon Hydraulic Dump Truck
What else do you need:
  • Battery and charger
  • 1x Hydraulic Oil – Part # VVV-S0014
Retail Price: $2999.99
Map Price: $2599.99
    引用 zwtnt168 13-2-25 12:38
    3000美元在欧洲可以买个1:1了
    引用 大麻雀叔叔 13-2-24 20:55
    还是没有scaleART呢好!
    引用 臭兔兔 13-2-24 20:36
    什么时候做个军卡,绝对支持!
    引用 蠢蠢欲动 13-2-24 13:32
    车头貌似用200RMB雷虎MAN头改的。
    引用 心心心 13-2-24 12:21
    看配件全部是 东莞  静点模型 家的东西
    引用 zeu 13-2-24 11:35
    这很多东西看着眼熟啊
    引用 linke 13-2-24 10:39
    这个RC4WD是个大山寨么?
    引用 蠢蠢欲动 13-2-24 10:22
    3000美元=18703.2419人民币元
    引用 最终隔离 13-2-24 10:14
    好车啊 ,送我吧
    引用 super_弟 13-2-24 04:09
    马达的颜色让人情不自禁的想起xxd、、、、、、、、、、、、、、、、
    引用 小仔 13-2-23 22:22
    天价2999美元
    引用 长风大侠 13-2-23 22:12
    尼玛真的贵啊~
    引用 a318733 13-2-23 22:07
    价格不菲啊....
    引用 毓麒生 13-2-23 21:01
    那个波箱和前后车桥看着眼熟,国内某牌的吧?
    引用 KYB 13-2-23 20:56
    3000美金?  10000RMB还能接受
    引用 hippo90929 13-2-23 20:28
    3000美金。。。。。。消受不起啊啊
    引用 frxrrbluex 13-2-23 20:24
    好车  连接 价格啊
    引用 蠢蠢欲动 13-2-23 19:56
    好车
    引用 zhangjh 13-2-23 19:17
    给个链接啊
    引用 zhangjh 13-2-23 19:15
    3000人民币
    查看全部评论(25)
