Tekin RS GEN2 电子变速器
13-3-31 22:34| 发布者: rcfans| 查看: 6082| 评论: 3
Tekin推出RS GEN2电子变速器,延续RS产品的高性能和可靠性。支持无刷和传统有刷马达,使用高压可编程BEC,最高支持8.5T马达(无刷,有刷仅有前进和刹车支持到10T,有刷前进和倒车支持12T),可使用2-3S锂电,Tekin强调这款产品的油门和刹车精准度以及平滑度是前所未有的。 无论是入门级玩家还是有经验车手,RS GEN2都能够提供极佳性能表现。
Features:
  • Ultra-smooth and Precise Throttle and Braking Control
  • Compatible with Sensored/Sensorless Brushless and Brushed Motors
  • Easily Access Programming, Anywhere, Anytime
  • Datalogging Capability
  • High Voltage Programmable BEC
  • EZ Access HotWire Programming Port
  • HotWire PC Interface for Advanced Programming and Updating
  • D2: Dual Drive Mode Technology
  • On-Board Temperature Indicator
  • HDAC: High Density Copper PCB’s
  • Sensor Plug for Precise Commutation with all Motors
  • Gold-plated Solder Posts for Easy Wire Replacement
  • Self Test Diagnostics and Factory Reset
  • Pit Tune Mode
  • DGF2: Digital Glitch Filtering V2
  • QuickTune™ Programming
  • One-Touch Radio Calibration
Program Features:
High Voltage BEC (6.0v/7.4v)*
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (13 steps)
Timing Profiles (5 preset – 2 custom*)
Adjustable Throttle and Brake Minimums
Custom Throttle Curves
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2S, 3S, Custom)
Timing Boost and Turbo when used with Hotwire
ROAR Race Spec “Blinky” Mode
Save, Load and Share custom ESC setup files
Extensive Tuning via Tekin HotWire PC Interface
*Requires HotWire Sold Separately
Specs:
Controls: Forward/Brake/Reverse
Input Voltage: 4-9 Cells, 2S-3S Lipo
BEC: 6.0v / 7.4v 5.5amps
Motor Limit Brushless Mode: 8.5 Turn, 540 2-pole (36mm)
Motor Limit Brushed Fwd Only Mode: 10 Turn
Motor Limit Brushed Fwd/Rev Mode: 12 Turn
Timing Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.0 x 1.3 x .51in (25.4 x 33 x 12.9mm)
Weight: 2.0oz / 48g with wiring
    引用 skyphilips 13-4-1 22:47
    觉得这电调的正面像张脸  ._.
    引用 RANKS 13-4-1 16:21
    好囧的电调
    引用 TIGER9901 13-4-1 12:49
