Losi 新款Mini 8ight 越野车
13-7-27 15:39| 发布者: rcfans| 查看: 13184| 评论: 4
Features:
  • Includes Dynamite® 4500Kv brushless motor and waterproof ESC
  • Spektrum™ SR200WP Water Proof receiver with 2.4GHz DSM® technology
  • Spektrum™ DX2L Radio
  • 7.2V 1100mAh NiMH battery pack with EC2™ connectors
  • 4WD shaft-driven drivetrain
  • Front and rear metal gear differentials
  • Water Proof Mini servo with saver
  • Aluminum, threaded, oil-filled, coil-over shocks
  • Heavy-duty, 2.5mm anodized aluminum chassis
  • Mini Kingpin™ treaded tires
  • 2.5mm aluminum shock towers
  • 12mm wheel hexes
  • Aluminum motor mount
  • Heavy-duty adjustable turnbuckles
  • Chassis dirt guards
  • Limited Edition Dakotah Phend or Adam Drake Body
Specs:
Completion Level: Ready-To-Run
Drivetrain: 4WD
Recommended Environment: Off-Road
Size/Scale: 1/14
Vehicle Type: Buggy
Batteries: 7.2V NiMH (included, LiPo option available)
Charger: Included (not sold separately)
Chassis: 2.5mm anodized aluminum
Height: 4.33 in (110mm)
Length: 11.49 in (292mm)
Minimum Age Recommendation: 14 years
Motor or Engine: 4500Kv brushless motor
Radio: 2.4GHz DSM Technology
Shock Type: Aluminum, threaded, oil-filled
Speed Control: Brushless
Tire Type: Kingpin Buggy
Weight: 2.15 lb (0.98 kg)
Wheelbase: 7.32 in (186mm)
Width: 8.03 in (204mm)
12
    引用 Lu°远 13-7-28 00:34
    裸露的塑胶大齿终究是这车最大的缺点
    引用 askrun 13-7-27 18:51
    和老款有撒区别?壳子还是老款的好看
    引用 咸萝卜勇士 13-7-27 18:02
    防水舵机、接受、电变,听上去不错。。
    引用 liu381004376 13-7-27 16:02
    多少钱啊~地平线网店还没卖啊~
