RGT R2 Prospec 蓝色限量版
13-10-14 12:13| 发布者: rcfans| 查看: 6889| 评论: 0
瑞泰RGT Hobby 推出R2 Prospec 蓝色限量版(Blue edition) 4WD 电动房车。竞赛级产品,使用了2.0mm厚度的碳纤底板和二楼板,碳纤油压架,铝制波箱,短身大容量避震,可调车架扭动特性,可使用符合ROAR规定的各款2S锂电,铝制摇臂座和钢制前后传动轴等高性能零件,全球限量500台。RGT将以极高性价比推出R2 Prospec 蓝色限量版(Blue edition) 4WD 电动房车,让更多人参与电房活动。
点击这里->进入RGT品牌专区参与互动
特性
– 2.0mm carbon main chassis
– Carbon fibre top deck
– Carbon fibre shock towers
– Blue aluminium lower bulkheads
– Blue aluminium motor mount
– Blue aluminium wheel hex adapters
– Blue aluminium upper deck supports
– Hard-anodised aluminium low-profile shocks
– Adjustable caster, camber, anti-squat and toe
– Heavy duty belts
– Composite heavy duty gear differential
– Aluminium differential outdrives|
