lx0836 论坛元老 发消息
发表于 10-4-8 15:35:58 |显示全部楼层 来自: 中国山东德州
出去验收刚回来 就发现论坛分区发生了变化 也没太在意
过了一会儿突然发现有个SC区 太高兴了啊 就想发点东西 想发什么好呢 就发新出的SC10FT吧 看着图片解解馋
Option parts included in the SC10 Factory Team:
- ’09 Championship Body with decal kit
- JConcepts Subcultures SCT rear tires with molded foam inserts (1 pr.)
- Ball differential with lightweight outdrives
- Factory Team V2 dual-cap hard-anodized shock bodies with threaded collars
- Bleed-screw shock caps
- Suspension mounts for 4°, 3.5°, 3°, and 2.5° rear toe included
- Carbon-fiber battery strap
- CVA joints with pin retainer clips
- V2 slipper assembly with high-rate spring and Factory Team Gold pads
- Factory Team blue Titanium Turnbuckles
- Factory Team blue milled motor plate
- Factory Team blue aluminum servo mounts
- Factory Team blue aluminum wheel spacers
- Factory Team blue aluminum hinge pin brace
- Factory Team blue aluminum shock bushings
- Factory Team blue aluminum shock pivot balls
SC10 Factory Team Additional Kit Features:
- Factory Team blue aluminum screws for body mounts
- Factory Team blue cone washers for top plate Factory Team blue aluminum servo saver nut
- Gray Rear and Red front shock springs
- Updated suspension settings for Short Course racing
- Updated chassis and front suspension arms for increased durability
- Updated rear wheels with more drive pin support
- Built on 7-time National Champion RC10 T4 platform.
- Realistic Short Course Racing Truck 0.040” polycarbonate body
- KMC-style wheels, front and rear
- SC10 all-terrain front tires with molded inserts
- Realistic bumpers front and rear for maximum durability
- Rubber AE logo mud flaps
- 2.6:1 ratio Gearbox equipped with sealed gear differential
- Complete set of precision ball bearings
- Fully adjustable camber and toe-in
- Angled bell crank “co-planar” steering with built-in servo saver
- Vertical ball end adjustment, front and rear
- 30° caster blocks
SHAHOO_MAO 金牌 Fans 发消息
发表于 10-4-8 15:44:11 |显示全部楼层 来自: 中国北京
漂亮啊 ,好车啊
邦德座驾 超级元老 发消息
发表于 10-4-8 16:53:38 |显示全部楼层 来自: 中国陕西西安
厂队版应该是新近上市吧,车壳好看,装备更加强大得没话说,肯定是迎战BLITZ ESE的利器。
nfs9 长老 Fans 发消息
发表于 10-4-8 19:21:56 |显示全部楼层 来自: 中国浙江杭州
嗯嗯,新区有了
lx0836 论坛元老 发消息
发表于 10-4-8 21:41:02 |显示全部楼层 来自: 中国山东德州
这车最吸引我的一点就是避震 终于摆脱了AE原来的形式 O圈不是从上端卡进去的 而是在底端装入 貌似还增加了泄油孔 方便装配
游来游去的鱼 终极 Fans 发消息
发表于 10-4-8 21:48:51 |显示全部楼层 来自: 中国浙江杭州
kaojur32 终极 Fans 发消息
发表于 10-4-8 21:54:30 |显示全部楼层 来自: 中国上海
不错 挺漂亮的
