MotoGP世界冠军将使用Hudy工具
14-7-11 23:20| 发布者: rcfans| 查看: 7228| 评论: 6
获得过两次MotoGP世界冠军车手Casey Stoner(凯西-斯通纳)在退出摩托车比赛后(2013年)进入了遥控车世界。Hudy宣布Casey Stoner将开始使用Hudy工具,Casey Stoner目前拥有Yokomo 2WD和4WD电动越野车,还拥有Hong Nor Pro4卡车。关于: 凯西-斯通纳,生于1985年,澳大利亚职业摩托车赛车手,曾效力Ducati官方车队和本田官方车队。
和Hudy合作后,Casey Stoner说:
Being a professional sportsmen learned me that if you want to be best you need to work with the best. I was truly impressed by the quality and easy to use of all the Hudy products and there is nothing else I want to use. Either you take your hobby & sport seriously or for fun, there is nothing better than Hudy.
    引用 wjytopgear 14-7-14 16:32
    跨界
    引用 johnnyblaze 14-7-12 21:17
    斯通纳!
    引用 弱水三 14-7-12 17:34
    日本知名演员加藤鹰先生将开始使用杜蕾斯CONDOM,和DUREX合作后,加藤鹰说:
    Being a professional sex-sportsmen learned me that if you want to be best you need to work with the best. I was truly impressed by the quality and easy to use of all the DUREX products and there is nothing else I want to use. Either you take your AV-life seriously or for fun, there is nothing better than D ...
    引用 StanShaw 14-7-12 10:30
    如果赞助一个遥控器都拿不稳的摩托车手干嘛不去赞助个什么七八十岁美国前州长,天朝某村长没准知名度还高点。虽说hudy算不上大厂但是多少得有点职业操守吧....
    引用 明镜止水 14-7-12 08:57
    ducati车友来顶。。。
    引用 richmond 14-7-11 23:34
    看标题以为是小飞侠罗西。遥控车能满足他?
    查看全部评论(6)
