Spektrum 的2.4GHz产品有很高的知名度而且被世界各地玩家使用。Spektrum不甘心只为各大遥控品牌制造2.4G模块,发布了全新DX3R DSM2三通道遥控设备!请留意,这套设备是使用DSM2技术,反映速度比以往的2.4G和传统PPM都要快(大家以后不会再说2.4G不够FM,PCM快了)!DX3R的功能和各大品牌顶级遥控差别不大,具备30组记忆,舵机监测等特别功能!
Key Features
30 model memory Digital trims Graphically depicted exponential Graphically depicted travel adjustment Trim rate adjustment Steering dual rate Steering dual rate override Frame rate Servo monitor Switch assignment Model reset Model copy Sub Trims 3 timer functions: countdown, count up and integrated
接收机体积小了很多,相比以前的2.4G
