Traxxas Velineon Brushless Horsepower[无刷系统]
07-5-26 15:34| 发布者: BAMBOO| 查看: 3490| 评论: 0
Traxxas的新Velineon Brushless无刷系统是给1/10车架使用!大家可以先看看以下视频介绍就会明白这套产品的威力!
视频: http://www.traxxas.com/ftp/promo_mov/velineon.wmv
具体参数
Velineon VXL-3s ESC
• Compatible with brushed, brushless, and sensored brushless motors
• Auto-detects the motor type
• Accepts NiCad, NiMH (4-10 cells), and LiPo (2-3 cells) battery packs
• Built-in two-stage low-voltage detection for LiPo battery packs
• Three drive profiles: Sport Mode, Race Mode, and Training Mode™
• Gold-plated motor connectors
• Incredibly smooth sensorless operation
• Two-Stage Thermal Shutdown Protection
• Built-in auxiliary fan output for optional cooling fan
Velineon 3500 Brushless Motor
• Consistent, high-power output, run after run
• Low-maintenance
• Unique Traxxas design
• Ultra High-temp Neodymium magnets
• Efficient, high-speed ball bearings
• Precision-balanced rotor
• Accessible solder tabs
• Protective end cap
• 10-Turn, 3500kV
• Optimized for extreme power and efficiency in 1/10 vehicles
Traxxas High-Current Connector
• Shrouded wire connections (no shrink tube required)
• Wide surface area, gold-plated terminals
• Reverse polarity protection makes it impossible to connect backwards
• Textured surface for easy gripping
• Compatible with high-current 12-gauge wire
• Secure, positive locking terminals provide consistent contact
• Maintains smooth precision feel and low resistance even after thousands of uses
