Mugen MRX6X 1/8 油动平路车
20-2-1 15:38| 发布者: rcfans| 查看: 3612| 评论: 2
Mugen Seiki推出全新MRX6X 1/8油动平路车,基于去年在Steel City R/C举行的IFMAR世界赛夺得冠军的车型进行升级,包括转向、尾部抓地力、传动系统和耐用度都进行了提升,战斗力再被提高。
Features of the new MRX6X kit (H2008) includes:
• New front suspension geometry. The new front uprights and aluminum bearing holders give you more overall steering and have a more precise steering feel. The shape of the upper front arm also changed to accommodate the current bodies on the market.
• The new front shock tower and lower shock mounts have new geometry that increase steering in the middle to the exit of the turn.
• New rear suspension geometry. The new rear upper A-arms and rear upper arm plate help improve rear traction.
• 0.8M pinion & spur gear. The new 0.8M pinion and spur gear will increase drive train efficiency. You’ll notice increased acceleration and increased runtime.
• New roll bar for easier refueling. This will allow quicker pit stops.
• New front drive shaft. The new front drives shafts allow increase steering angles and more overall steering.
• The front wheel lever (H2231) and rear wheel lever (H2232) are standard equipment on the MRX6X and allow easier installing/removing of wheels.
MRX6X New Parts:
H0272-B Front drive shaft
H2151-B Rear upper bulkhead
H2161L/R Front upright
H2162 Insert upright
H2163 Rear upper and lower arm
H2164 Rear upper arm plate
H2165L/R Front upper arm
H2166L/R Front lower shock mount
H2167 Roll over bar
H2233 Pinion 19T
H2234 Pinion 20T (Option)
H2235 Pinion 24T
H2236 Pinion 25T (Option)
H2237 Spur gear 60T (Option)
H2238 Spur gear 61T
H2239 Spur gear 62T (Option)
H2240 Spur gear 56T (Option)
H2241 Spur gear 57T
H2242 Spur gear 58T (Option)
H2422 Center Weight 30g (Option)
H2516 Front shock tower
    引用 pal 20-2-2 14:19
    danity: 我的全新4x还在
    出吗
    引用 danity 20-2-1 16:17
    我的全新4x还在
