Hong Nor X3GT 和 X3GTS 升级波箱套件
20-3-1 16:42| 发布者: rcfans| 查看: 5039| 评论: 4
Hong Nor鸿诺给X3GT和X3GTS车型推出全新前后波箱升级套件。开放式设计,CNC铝制,提升了悬挂系统的支撑强度,高速过弯更稳定,同时更易维护,每个波箱只需拆装4颗螺丝即可触及差速器。升级套件还包含碳纤避震架,差速托,轴承等相应零件。
具体零件包括
    X3GT-36A   Front Shock Tower x 1pcs
    X3GT-36B   Rear Shock Tower x1pcs
    X3GT-29A   CNC Differential Holder L x 2pcs
    X3GT-29B   CNC Differential Holder R x 2pcs
    X3GT-30A   CNC Differential Bearing Mount L x 2pcs
    X3GT-30B   CNC Differential Bearing Mount R x2 pcs
    X3GT-31    CNC Suspension Bracket, FF x 1pcs
    X3GT-32    CNC Suspension Bracket, FR x 1pcs
    X3GT-33    CNC Suspension Bracket, RF x 1pcs
    X3GT-34    CNC Rear Toe-in Mount Set x2pcs
    X3S-42A    Swaybar lnserts (2) 2-2.5mm x 2pcs
    X3S-42B    Swaybar lnserts (2) 2.5-3mm x 1pcs
    X3S-11A    Center CVD Shaft, Rear101.5mm x 4pcs
    X3S-37A    5x16x5 Bearing x 4pcs
    #277A     5x8x2.5 Flange Bearing x 4pcs
    3x3 Set Screw x 4pcs
    3x6 Cap Head Screw x 8pcs
    3x8 Button Head Screw x 4pcs
    3x12 Button Head Screw x 4pcs
    4x10 Button Head Screw x 4pcs
    3x10 Flat Head Screw x 4pcs
    3x12 Flat Head Screw x 4pcs
    4x10 Flat Head Screw x 4pcs
    Instruction Manual x 1pcs
http://www.hongnor-racing.com
http://www.rgt-racing.com
http://www.hsp-ydt.com
    引用 fudgoal432 20-3-1 23:11
    palmtwo: 看网址hsp把rgt和鸿诺都收了,啥时候出rgt 小短卡的配件啊
    HSP 是在闷声发大财吗
    引用 fish1221 20-3-1 22:54
    有种hsp附体的感觉
    引用 palmtwo 20-3-1 20:06
    引用 super胡桃夹子 20-3-1 19:59
    甩一壳油
