HB Racing E819RS 1/8 电动越野车
20-6-4 21:27| 发布者: rcfans| 查看: 6347| 评论: 3
HB Racing将推出E819RS 1/8 4WD电动越野车(BUGGY)。基于E819底盘进行研发升级,全新的V3后避震架,让车手/玩家能够调整尾翼和车壳柱高度,车架中央的强化支撑杆、全新的17.5° caster座、新的转向组件、更强壮的舵机保护器等都包含在新款E819RS产品内。产品编号HB204645。
新特性包括
NEW RS style V3 rear shock tower
NEW 2° Steering block set
NEW Revised caster block with larger set screws
NEW Delrin steering block bushings
NEW Screw-type shock pins
NEW Heavy duty servo saver spring
NEW Heavy duty aluminum center chassis brace
NEW 1 piece sway bar links
Narrow hex hubs
Heavy duty spur gear
43/13 front & rear differentials
Revised graphite rear hub carrier plates
Molded nylon rear wing
Front linkage geometry spacers
Fine adjustment aluminum D-Mount
Universal drive shafts
Dual clamp aluminum motor mount
Low CG fully adjustable battery mounting system
Accepts 4s packs, 2x2s, and 2x2s 'shorty' packs
HB monocoque suspension arms
Aluminum servo saver arm
One-piece lightweight wing mount
Carbon graphite steering arms
Adjustable steel turnbuckles
Big bore threaded coilover shocks
Hard anodized aluminum shock towers
Threaded outer hinge pins
Stand-up servo mounting
Sway bars front and rear
Split center bulkhead
Lightweight diff outdrives and center inputs
Lightweight front aluminum axles
    引用 Adonis 20-6-7 17:47
    HB终于出新车了
    引用 jeisa 20-6-5 00:40
    4000?
    引用 郑直 20-6-5 00:00
    顶一个
