ARRMA 1/5 4WD Outcast 8S EXB
21-6-4 20:53| 发布者: rcfans| 查看: 8493| 评论: 28
美国第品先(地平线)模型ARRMA发布全新1/5 4WD Outcast 8S EXB"放逐流浪者"新车。EXB版本(EXtreme Bash),进一步强化了车架,标配了更多的原厂升级件,让这台Outcast 8S EXB速度大脚越野车更坚固、更强壮,玩得更暴力!
换上了EXB的7075 T6 5mm厚度的CNC铝制底板以及钢制可调悬挂和转向连杆,20mm大容量避震器带6mm避震轴心,全面提升避震性能,弹跳还是飞坡轻松应对。
高抓的dBoots®轮胎加上星型多幅式轮圈,能够在各种地形行走,同时轮胎的使用寿命ARRMA也进行了改善提高。
三颗螺丝固定的电机座让EXB Outcast快速拆装马达,提升维护效率。
模块化的防水接收机盒、舵机座和电调托,除了让车架更整洁更好防止泥尘侵入,还能够更好保护电子设备。
除了强化底板,EXB Outcast的多层次强化车架结构,提升车架整体强度和刚性,具备ARRMA特色的中置支撑杠以及车头前后的倾斜支撑杆都作为标准配置。
传动部分,全金属的轴套和差速齿轮,大幅延长使用寿命。
EXB金属哑光效果车壳(Matte and gloss effect)让Outcast 8S EXB"放逐流浪者"新车更精神,车壳内部也进行了强化。尺寸长度714mm、宽度596mm、高度305mm、重量10.6kg。产品编号ARA5210。
详细特性和配置:
• EXB 7075 T6 5mm thick CNC aluminum laser-etched chassis plate
• EXB Red-anodized CNC aluminum front brace mount
• EXB Matte and gloss effect body
• Heavy-duty 8mm thick steel rear turnbuckles
• Heavy-duty 7mm thick steel steering turnbuckles
• Oil-filled adjustable 20mm bore shocks with 6mm thick shock shafts and new plush shock tuning
• Heavy-duty servo saver springs
• Front and rear sway bars
• Red-anodized aluminum 49 and 56 series motor plates
• dBoots® Back-Flip tires
• 47T and optional 39T Spur Gear
• Servo mounts for 1/5 and 1/6 servos
• Wheelie bar
• Front bumper with impact-absorbing design
• Easy-access 3-bolt sliding motor mount for quick motor removal
• Ultra-thick composite front and rear shock towers
• Black anodized aluminum rear lower chassis brace
• Multi-structured center brace system for maximum durability
• Heavy-duty drivetrain
• Easy-access front and rear diff module design
• All-metal diff outdrives and gearbox internals
• Durable steel driveshafts
• Durable wheel hubs for increased strength
• Easy-access waterproof electronics module
• Center body support and brace for maximum durability
• Strong composite chassis side pods
• 2-year warranty (see website support for details)
选购ARRMA产品请咨询迈杰罗遥控及授权经销商
    引用 韩文光 22-2-3 11:31
    这还行啊 可以买来玩玩
    引用 haoxintmd 21-6-8 00:17
    塑料避震塔,塑料避震器差评
    引用 小风车 21-6-7 00:39
    肯定会很好玩的
    引用 氯行氢蛙 21-6-6 00:19
    这个传动轴是不是细了一点?
    引用 木大头 21-6-6 00:12
    看来台风exb没戏了
    引用 我每天都有空 21-6-5 21:41
    有金属避震和避震架的时候就可以下手了
    引用 小风车 21-6-5 19:40
    爽  是越野的感觉
    引用 克洛泽 21-6-5 12:58
    这车满配的30斤吧,太沉了
    引用 特种矿卡轮胎 21-6-5 10:41
    1/5的RTR那车是不咋地
    引用 fqajian 21-6-5 10:29
    官方视频都很毒
    引用 GDavid 21-6-5 10:28
    帅呀
    引用 steinyan 21-6-5 10:15
    为什么arrma的广告这么好。看着就想从屏幕里吗一把拽出来
    引用 我的小可爱 21-6-5 09:59
    现在ARRMA配件挺好了,基本都有,没货的也很快了,比 ...
    引用 99kangaroo 21-6-5 09:52
    这遥控器是自带的?还是得加钱买
    引用 黄景伦 21-6-5 07:19
    已经超越T厂的广告了非常动感,一看就想买。
    引用 糖豆0520 21-6-5 06:07
    这车配齐下地 是不是要30斤
    引用 camry 21-6-5 02:28
    卡屯和他比怎么样?
    引用 JiAnQiuyE星辰 21-6-4 23:52
    这种大脚还是要玩大X 稳当点
    引用 samt8331730 21-6-4 23:11
    万物皆可exb
    引用 xmaxxtuning 21-6-4 22:44
    太小了 带个尾翼还比6车大X短一截 5个茅厕{:笑哭:}
    查看全部评论(28)
