HB Racing D2 Evo 1/10 2WD电越
22-5-26 17:49| 发布者: rcfans| 查看: 3518| 评论: 4
HB Racing推出D2 Evo 1/10竞赛级2WD电动越野车(Buggy),这是一台非常特别的产品,由设计师Torrance Deguzman负责开发,全车采用了大量的CNC铝制零件、碳纤零件以及合成尼龙材料制造,单壳体悬挂摇臂也从HB的1/8和1/10 4WD下放到2WD量产车型内。
HB Racing的D2 Evo拥有丰富的参数设定范围,能够适应全球各地各种赛道和环境作赛,首批量产1000台。产品编号204240。
特性
Aluminum front arm mounts with optional adjustable kickup
Monocoque suspension arms with carbon fiber inserts as pioneered by HB in 1/8 scale & 1/10 4WD
Gullwing suspension arm design front & rear
Aluminum caster blocks with caster adjustment bushings included
Adjustable Ackermann geometry via optional steering hub arms
Adjustable droop setting via droop screws similar to 1/8 scale buggies
Ball bearing supported steering bellcranks with aluminum steering rack
Flat plate aluminum chassis so optional materials like carbon fiber can be used depending on racing conditions Adjustable battery position with quick change O-ring retainers
Motor cooling fan mounts built into the side guards
Dual disc adjustable slipper clutch
Machined aluminum gearbox with 3-gear laydown configuration
Easy access differential (ball & gear diff available)
Aluminum rear hubs with inserts for various hinge pin heights
Fully adjustable camber link position using spacers
Both inboard and outboard camber mounts can be finely adjusted up & down as well as inward & outward
Clamping aluminum wheel hex drives
Arm mount inserts for toe-in and anti-squat adjustment
    引用 Monster007 22-5-27 19:38
    这个普及率好像有点太低
    引用 HONDA鸫 22-5-27 06:06
    与某大品牌结构几乎一模一样
    引用 肥仔威 22-5-26 20:35
    跑这个牌子世界赛进前十的那位兄弟现在已经创立了自己的MAYAKO{:旺柴:}
    引用 快使用双截棍 22-5-26 18:36
    世界赛总见这个牌子,销量总见不到这个牌子,很不错的牌子,为啥没人买
