Vanquish Products F10T铝制直桥桥壳
22-9-28 16:58| 发布者: rcfans| 查看: 4291| 评论: 13
Vanquish Products(攀爬区的朋友简称VP)推出F10T铝制直桥前后桥壳,随着VS4-10直桥版本车型发布,原厂的铝制桥壳也正式推出,整合了C座设计并增加了前止推杆固定座(panhard),可以安装AR44齿轮组或直桥。提供黑色(产品编号VPS08632)和银色(产品编号VPS08633)电镀外观供选择。
Recommended use with the following:
    Vanquish VS4-10 Kits equiped with straight axles such as the Origin, Pro and Phoenix (Straight Axle version)
    Vanquish Products VS4-10 Chassis Kit. PN VPS10130*
    Incision S8E 90mm Shocks (Offset pivot ball at shock mounting location)  PN IRC00501.
    Incision Rod Ends and Pivot Balls (.280" width pivot balls)**
    Vanquish Products 6-Hole AR44 Gear set. PN VPS08330
    Vanquish Products 6-hole AR44 Spool. VPS08070
    Vanquish Products Rear axle shafts VPS08082
Features:
    Machined in the USA
    Made from high quality domestic produced aluminum
    Scale import truck style axle housing
    Adjustable rear upper link positions
    Comes with One Piece Bearing Retainers
    Double shear shock mounts for S8E offset pivot balls allowing for more shock tuning adjustment
    Rear Bearing Retainer Caps utilized to eliminate the need for lockouts and provide a more scale appearance
 Includes the following:
    1pc F10T Rear Housing
    2pcs Bearing Retainers
    1pc  F10T Third Member
    2pc Axle End Caps
    Required hardware
    Instructions
选购Vanquish Products产品
请联系酷乐派模型(KLP)
https://klprc.taobao.com
    引用 reclife 22-10-1 12:33
    Yota真好看
    引用 咖喱鱼丸 22-9-29 23:15
    我选yota
    引用 小菜儿“” 22-9-29 12:55
    价格高的离谱
    引用 Ayer 22-9-29 12:07
    还行价格降一点更好
    引用 Lzt 22-9-29 09:55
    丑出天际线
    引用 bakersoso 22-9-29 09:14
    价格过于vp
    引用 silversol 22-9-29 09:04
    除了不好看没别的缺点
    引用 caolemeng 22-9-28 21:53
    能买
    引用 小拳头 22-9-28 21:43
    酸葡萄有时也挺好吃。
    引用 zzz888666 22-9-28 19:51
    哈哈仿真真的玩不明白哈哈哈
    引用 张老丝 22-9-28 17:39
    赶紧出管架,仿真你玩不明白
    引用 阿铜木 22-9-28 17:25
    连个前桥的照片都不放出来……
    引用 mrz8080 22-9-28 17:15
    麦不起系列666
    查看全部评论(13)
