Tamiya XV-02RS Pro
23-6-14 20:09| 发布者: rcfans| 查看: 4798| 评论: 13
几天前Tamiya田宫模型预告了XV-02RS Pro,偏向"公路"行走的新款RS型号,今天这款新车的产品照片公布。产品编号58726,上市日期待定。
– Features oil shocks with aluminium cylinders employing shaft length suitable for road performance and dedicated 3.5mm thick carbon fibre shock mounts and carbon fibre reinforced rigid lower deck.
– The 18-spoke wheels are matched with semi-slick racing tyres.
– Front mid-mounted engine plus long front and rear drive shafts of identical length.
– Comes with two 39T differential gears and one 40T differential gear for front and rear drive adjustment.
– Use 39-tooth gears (with 15-tooth gears) at the front and rear for standard transmission balancing, 39-tooth gears (with 15-tooth gears) at the front and 40T gear (with 15T gear) at the rear for forward transmission balancing, and vice versa for rearward transmission tilt balancing. *Use the latter two with slipper clutch and centre differential.
– The longitudinal battery pack is positioned to the centre left for optimal balance.
– The flat bottom of the chassis and the slip angle on the front bumper further contribute to limiting surface contact.
– The caster blocks feature a six-degree angle.
– Includes universal drive shafts front and rear and an aluminium servo mount.
– Please note that a polycarbonate chassis cover is not included in this version.
选购Tamiya产品请进入
    引用 Rottenhand 23-6-19 11:34
    tt02 srx直接被薄纱
    引用 Star泼辣酱 23-6-17 21:33
    没啥卵用,也就是能装低车壳了
    引用 HAOLONG 23-6-17 11:34
    区别还是有,op了碳纤维避震架,这个单独买也要200元吧,还换了更好的开放式强化球头帽
    引用 白い悪魔 23-6-16 21:23
    除了缩短行程其他没啥区别
    引用 tims 23-6-15 21:48
    等op件
    引用 银速度 23-6-15 15:20
    离地从3厘米收到了1.5厘米以下
    引用 喜哥 23-6-15 13:09
    又一神作,必须入手
    引用 danity 23-6-15 08:48
    给xv01准备的短避震和架从来都没用上过
    引用 Star泼辣酱 23-6-15 03:57
    估计在XV01-TC面前毫无胜算
    引用 蓝绝 23-6-15 01:49
    有没有可能,铝合金阳极拉杆无论在哪个厂家都是op件
    引用 伝説の龍 23-6-14 21:07
    TT03
    引用 叫啥都重名 23-6-14 20:47
    好抠,蓝色拉杆都不给
    引用 Zz踢 23-6-14 20:20
    跟xv01 tc差不多类型的呗
    查看全部评论(13)
