MST RMX EX S PRO 漂移车
24-3-20 20:20| 发布者: rcfans| 查看: 3739| 评论: 7
MST(Max Speed Technology 得隆科技)推出RMX EX S PRO竞赛级1/10 RWD后驱漂移遥控车,轴距257mm(+-3mm)。
RMX EX S PRO采用了新设计的前后悬挂以及短身弹簧套件,配合新款ATK V2转向组件拥有新的Ackermann角度设定,能够提升大角度弯道漂移过程中的操控稳定性,无论在入弯还是出弯,让玩家操控自如,入门级的价格享受竞赛级的表现,实际上RMX EX S PRO是同厂碳纤型号RMX EX GT的入门版本。THA可调短身悬挂摇臂也标配在RMX EX S PRO后悬挂,增加车架滚动。MST这款新车还附带高重心(更具侵略性的操控)和低重心(更稳定的操控)后臂码供玩家设定。产品编号532213。
特性:
 -The newly designed ATK V2 Front steering block is used with a new Ackermann setting that provides aggressive and flexible steering at the beginning of the turn and can handle larger drifting angles in the later stages of the turn capable of stable driving during high-angle drifting.
-The new design THA adjustable short arms are used in the rear with long-type suspension arm mounts to increase rear roll and improve flipping speed and corner exit acceleration.
-All-new designed rear aluminum arm mount -2 paired with newly designed elongated arm mount +12 compatible with +13.
-Free choice of preferred high/low center of gravity control modes:
  *High center of gravity mode for aggressive handling.
  *Low center of gravity mode for stable handling.
-Equipped with new-designed rear spur-gear-driving gearbox is switchable for RMX and RRX drive mode.
-Utilizes new gear differentials with #3000 silicone oil for optimal differential performance.
-FRP chassis with 2.0mm thickness maintains moderate rigidity.
-Dual-piece FRP upper deck with 3.5mm thickness enhances chassis rigidity.
-New designed front damper stay.
-New designed front upper deck connecting bracket.
-New designed DK-RWD front/rear short spring set.
-Lightweight quick-release battery mount.
-New designed lightweight front bumper/rear handle.
    引用 伝説の龍 24-4-13 18:35
    MST漂移的末路了
    引用 spacex 24-3-25 19:41
    沒花樣搞了
    引用 Battosai 24-3-22 18:22
    这布局放在三年前还是不错的
    引用 森仔 24-3-22 04:07
    这波箱真特么丑
    引用 unclemud 24-3-21 10:44
    是不是前后摆臂数量做多了回不了本,又弄个这胶车卖?
    引用 亚蒙 24-3-21 01:55
    鬼岛那家公司吗 产品有很多问题
    引用 CarreraGTX 24-3-20 23:04
    都从碳纤维回归塑料了么?比碳纤维拥有更好的扭转特性,然后再从塑料进阶到碳纤维?比塑料拥有更强的刚性
    查看全部评论(7)
