Futaba 4PK 2.4GHz 遥控器
07-10-24 09:40| 发布者: jovi| 查看: 4433| 评论: 1
Futaba 4PK热辣登场,它独特的外形引起了很多FANS的关注。不单外形,它的手感也很平衡,符合人体工程学,而且仅重700克多一点。即使在漫长的决赛中也不会太累。
转轮反应很准确,而且可以调整扳机的位置以适应手型。 它有40组记忆,12字符的命名,分辨率达到2048,而且有第四通道,可以方便的调整大脚车的前后刹车比例。最重要的是,4P内置了2.4G的系统,还有FASST系统。
Features
- Much consideration went into the design of the 4PK’s grip, which is slightly thicker to accommodate larger hands.  Besides being lighter, the transmitter’s weight is well balanced for added comfort.
- Achieve perfect “feel” in seconds with the Advanced Positioning Adapter.  You can drop the wheel down, move it left or right, even change the angle – a feature many drivers have requested.
- The trigger position can also be shifted by as much as 7 mm.  This allows you to customize the radio for sharper response based on finger size.
- The redesigned keypad features a large 4-direction jog button for quick access and scrolling.  Important functions can be assigned to buttons on the wheel housing to keep them within easy reach.
- Not only is the backlit LCD screen large enough for easy reading without eye strain, it’s also angled for instant viewing without having to tilt the transmitter.
- Because the 4PK was engineered from the beginning for 2.4GHz modulation, there’s no long, unwieldy antenna.  Instead, the antenna is shorter and lighter in weight, folds down for easy storage, and pivots for optimum reception.
- No NiCd battery here – the 4PK comes with an 1700mAh NiMH pack that’s comparable in size, but with almost twice the capacity.  That means about TWO HOURS of operation on a single charge – enough for the longest of mains and maybe even an entire weekend of racing!
- The included R604FS receiver features Dual Antenna Diversity (DAD) for reliability and security.  Its compact size (1.54 x 1.02 x .55 inches) and weight (0.49 ounces) lets you use it in the tightest installations.
4PK System Overview:
- 40-model memory
- 10-character model naming
- 4th channel for brake bias, throttle adjustments, etc.
- 2 programmable mixes
- Assignable button, trims and dials
- Digital trims and dials
- Advanced Positioning Adapter (APA)
- Adjustable trigger location
- Backlit 128 x 64 white LCD screen with adjustable contrast
- Subtrims, servo reversing and EPA on all channels
- Fail safe
- DSC (Direct Servo Control)
- Exponential & Adjustable Servo Speed (Steering/Throttle)
- Up/Down, Lap & Systems timers
- 100-lap memory
- ATL (Electronic & Mechanical)
- Traction Control/Acceleration Rate
- ABS braking system
- Boat mixing
- Idle-Up
- Tx NiMH and Dual-Output Charger
4PK Specifications:
- “New Driver”, “Race-Ready”, “Expert” and “Big Car” menus that add functions based on driving skill level and experience
- Throttle Mode Select, for selecting acceleration/brake servo neutral points between 70/30 for nitro or 50/50 for electrics
- Vibrating alert system
- “Direct Select” single-button access to eight preassigned functions
- Navigation Lap Timer that sounds when target lap time is exceeded
- Servo Display Screen shows set-ups/mixes for individual servos (Expert Menu)
- Throttle programming options, including 5-point curve, Expo and VTR
    引用 iyvebb2006 07-10-25 13:12
    有没有搞错啊? 什么时候上市啊??
