Traxxas REVO 2008白金版
08-3-2 20:42| 发布者: jovi| 查看: 3882| 评论: 0
REVO 2008白金版是为了进阶车手而设计的。经过6个国家的比赛系列之后,Traxxas把所有新的,超过50样改装特性都融合在此款白金版车子当中,它将是史上性能最强的的竞赛级大脚车。
New 2008 Platinum Edition Features:
• Larger 150cc Revo fuel tank for superior sealing
and consistent fuel delivery during long mains
• Compact receiver and battery box with an integrated personal transponder mount
• New high-volume dual-stage air filter
• Sway bar kit with red-anodized front turnbuckles
• Compact throttle servo mount with air filter support
• Large-bearing nylon axle housings with steel pivot ball retainers
• Digital waterproof servos for steering and throttle deliver 125 oz-in & 0.16-sec transit time
• Titanium-anodized chassis and chassis brace
• Mirror-polish Resonator dual-chamber tuned pipe
• Durable spring-mounted header allows movement to prevent impact damage
• Aluminum 17mm splined wheel hubs & hex nuts that are also compatible with standard 17mm hex wheels
• Response Pro tires with foam inserts
• Clear, trimmed, fastback racing body
REVO® 2008 Platinum Edition Features
• Larger 150cc Revo fuel tank for superior sealing and consistent fuel delivery during long mains
• Hard-anodized, Teflon®-coated GTR shocks
• Smooth and durable TiN shock shafts
• Variable damper shock pistons
• 50WT shock oil, orange front & gold rear shock springs
• Tight-handling progressive-2 rockers
• Digital waterproof servos for steering and throttle deliver 125 oz-in & 0.16-sec transit times
• Integrated personal transponder mount
• Includes rechargeable high-capacity NiMh receiver battery pack and on/off wiring harness
• Autoshifting two-speed is simple, reliable, & easy to adjust
• Forward-only transmission reduces rotating mass
• Close ratio two-speed gear set for smooth power delivery
• High-performance vented front disc brake
• Dual-disc rear brake kit with adjustable linkage
• Sealed center differential with 500K weight oil
• Mirror-polish Resonator® dual-chamber tuned pipe
• Durable spring-mounted header allows pipe movement to prevent impact damage
• Ball bearing throttle bellcrank with lightweight return spring
• Black silicone exhaust coupler and deflector
• Machined aluminum 40mm flywheel for use w/ starter boxes
• High-revving TRX 3.3 Racing Engine for proven championship-winning horsepower and speed
• IPS crankshaft and backplate for maximized horsepower
• TUBES red-anodized 7075-T6 front and rear toe-links
• Red-anodized push rods with steel threaded inserts
• Extended wheelbase, adjustable rear suspension arms
• Formula-1 style high-downforce black Revo wing
• Wing mount offers adjustable height and deflection angle
• Response Pro tires with performance-tuned foam inserts
• 3.8" White dish wheel uses innovative 17mm splined hex that is also compatible with standard 17mm hex wheels
• Aluminum 17mm splined wheel hub and hex nut
• Includes 17mm molded wheel wrench
• New steering components allow maximum steering throw
• Large-bearing nylon axle housings with 13mm outer bearings
• Steel pivot ball retaining rings
• Compact black-chrome bumpers
• Blue-anodized antenna crimp nut
• Low-profile body posts
• 50k weight front and 10k weight rear differential oil
• Clear, trimmed fastback racing body
Includes the following tuning options:
o Tuning shock springs
o 40WT and 60WT shock oil
o Thick sway bars
o 36-Tooth and 40-tooth spur gears
o 16-Tooth Clutch Bell
o Y-harness for dual steering servos
