GRP .21 越野车引擎
08-7-6 17:48| 发布者: jovi| 查看: 2336| 评论: 0
意大利GRP公司的技术总监是著名的Mario Rossi。这款1比8非改装竞赛引擎使用高质量材料制造,工序严格。引擎的温度控制系统(TCS)可以阻止热量向化油器传递,减少因此产生的进气干扰。
引擎的零件都可以跟GRP的改装系列引擎互换,这意味着您可以随意更换升级零件以改进性能,而无需整个购买新引擎。引擎还配备塑料盒子和贴纸。
Features
  • .21 Non-tuned racing engine for 1/8-scale buggies
  • Aluminum 7.5mm carburetor
  • Produced in Italy by GRP, under the direct technical supervision of Mario Rossi
  • Engine components are interchangeable with GRP tuned engine parts for easy performance improvement
  • Features true ABC construction
  • Comes in a GRP plastic box complete with decals
Product Specifications
  • Type:1/8 Buggy
  • Displacement:.21 cu.in.
  • Bore:16.27 mm
  • Stroke:16.79 mm
  • Engine (Only) Weight:355 g
  • Crankshaft Threads:14 mm
  • RPM Range:max 38.000 RPM
  • Fuel:Nitromethane
  • Cylinder Type:ABC
  • # of Ports:5
  • Carb Type:Aluminum
